Electrical Storm U2 - BUP offset dosen't match IFO header
fosslinux
#1 Post by fosslinux » Sun May 26, 2019 6:03 am
When I'm trying to turn the disk "Electrical Storm U2" into MKV, I get this error
MakeMKV v1.14.3 linux(x64-release) started
The program can't find any usable optical drives.
Opening files on harddrive at /cdrom/VIDEO_TS
Calculated BUP offset for VTS #1 does not match one in IFO header.
1. What does this mean?
2. Is there anything I can do to fix this?
Grauhaar
Re: Electrical Storm U2 - BUP offset dosen't match IFO header
#2 Post by Grauhaar » Sun May 26, 2019 4:18 pm
The BUP Offset error, is not the problem. Happens on nearly any DVD. It's only a backup file.
I think the problem is that the content is opened on the harddive and not on an DVD drive. Do you have Debug Log (must be enabled in the settings).
Good Luck :)
