Defaut Output Folder with AutoMounter
johnnygoodface
Post by johnnygoodface »
Hi gang,
I'm running MakeMKV on MacOS.
I'm also using the AutoMounter app to mount my NAS shares, so a typical path would look like this
/Users/jean/Library/Containers/nz.co.pixeleyes.AutoMounter/Data/Mounts/192.168.1.200/SMB/Transit/MakeMKV
So, I've setup the MakeMKV data directory to that same path.
But when it's time to extract, the Output Folder is still /Volumes/Transit/MakeMKV, NOT the above default path, and thus of course it's complaining: "Directory /Volumes/Transit/MakeMKV does not exist. Do you want to create it?" :(
So I have to manually copy/paste it to the Output Folder, then it works, of course :?
Why is MakeMKV not using my default path? :?:
Re: Defaut Output Folder with AutoMounter
What are your settings on the Preferences->Video page for Default destination? Both the radio buttons and the text box?
johnnygoodface
OMG! I can't believe I didn't notice that!
STBS (Sorry to be stupid! :roll: )
No problem. Actually, the settings there can be "mostly correct" and be "very irritating" at the same time. :)
