Disc fails on backup immediately with following errors
TheShoe
Post by TheShoe »
Attempting to backup Fantastic Mr Fox - an older titile.
Immediate errors and fail:
DEBUG: Code 0 at g75u^zn^>U:IVZGA(]>:213132698
DEBUG: Code 0 at \njBo?vhlq/vib}6Jnjy:121265154
Backup failed
Tried two drives. The disc is clean, no scratches.
Latest makemkv.
Re: Disc fails on backup immediately with following errors
do you have debug logging enabled? there should be more to the error messages than just the debug messages...
TheShoe
Post by TheShoe »
i do.
there's no additional messages in the log either (the "xxxxx's are my doing. not sure if that is PII or not)
log started at Sat May 25 18:22:23 2019 , written by MakeMKV v1.14.3 win(x64-release)
001005:0000 MakeMKV v1.14.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\xxxxxxx/MakeMKV_log.txt
005072:0000 Backing up disc into folder "Q:/RAIDMain/Movies/Fantastic Mr Fox/Fantastic Mr Fox (2009-1080p-BD)/FANTASTIC_MR_FOX"
SDF v05c: HL-DT-ST_BD-RE__WH16NS60_1.00_xxxxxxxxxxxxxx
001011:0000 Using LibreDrive mode (v05 id=xxxxxxxxxxx)
DEBUG: Code 2147483648 at 3n|Kn0<$@PHq+zen:29397035
001003:0020 DEBUG: Code 0 at g75u^zn^>U:IVZGA(]>:213132698
001003:0020 DEBUG: Code 0 at \njBo?vhlq/vib}6Jnjy:121265154
005069:0080 Backup failed
005080:0204 Backup failed.
TheShoe
Post by TheShoe »
Closing the loop on this:
For reasons unknown, the directory on my NAS that I was attempting to write into had permissions set such that MakeMKV could not write to it. A simple chmod fixed that.
There is no issue with the disc or makemkv.
