disc backup error msg - know what it is?
TheShoe
#1 Post by TheShoe » Fri May 24, 2019 8:30 pm
Backed up the Karate Kid UHD but saw 5 instances of the following:
DEBUG: Code 0 at KzKn#WzdJHAB/m5p8:121266603
Curious what it means and whether or not I have a complete backup. MakeMKV reports it completed, but those error messages appeared anyway.
This is a USB 3.0 ASUS BW-161DHT, Revision 3.00, Firmware is original, unpatched.
Re: disc backup error msg - know what it is?
#2 Post by Woodstock » Fri May 24, 2019 10:54 pm
If MakeMKV says the backup completed, it's been checked that the files match the checksums included on the disk.
Many (probably most) debug messages are just to let the author know what is happening with the data to be determined, and aren't "errors". I have no idea what standards Mike uses, but most programmers use "zero" as "no error".
TheShoe
#3 Post by TheShoe » Tue May 28, 2019 7:41 pm
I will add that I am now seeing this error a lot.
Ralph Breaks the Internet - UHD and BD - repeatedly, full disc backup and remux to MKV.
No ill-effects detected and will assume this is just debug for some use case.
Reporting it in any case.
