Guardians of the Galaxy Blu-Ray not copying
Bucky92
Post by Bucky92 » Thu May 23, 2019 2:03 am
Hi there,
I keep getting errors when trying to back up a copy of Guardians of the Galaxy on Bluray. Here is the log.
MakeMKV v1.14.3 darwin(x64-release) started
Optical drive "BD-ROM TSSTcorp DVDWBD TS-LB23D LB12d" opened in OS access mode.
File 00800.mpls was added as title #0
File 00200.mpls was added as title #1
File 00201.mpls was added as title #2
File 00020.mpls was added as title #3
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title #00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00210.mpls was added as title #4
Title #00090.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00029.m2ts was added as title #5
File 00030.m2ts was added as title #6
Title #00007.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00135.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00136.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00137.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00144.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00145.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00151.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00152.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00153.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00155.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00156.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00157.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00302.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00303.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00333.m2ts was added as title #7
Title #00334.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00335.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00336.m2ts has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00337.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00338.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00339.m2ts was added as title #8
Title #00342.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00343.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00344.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00345.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00346.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00347.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00350.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00351.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00352.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/Mac OS HDD/Movies
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9865396224'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9871749120'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9872209920'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9872209920'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9872474112'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9872799744'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9872928768'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9872928768'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9873389568'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9873389568'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9873653760'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9873653760'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9874046976'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9874305024'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9874305024'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9874569216'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9874569216'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9874833408'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9875484672'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9875484672'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9877192704'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9877843968'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9877843968'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9878765568'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9878765568'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9878784000'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9879023616'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9879023616'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9879035904'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9879060480'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9879287808'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9879306240'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9879349248'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '9879484416'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '9879484416'
Failed to save title 0 to file /Volumes/Mac OS HDD/Movies/MARVEL'S GUARDIANS OF THE GALAXY - BLU-RAY_t00.mkv
Encountered 97 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Re: Guardians of the Galaxy Blu-Ray not copying
Post by Woodstock » Thu May 23, 2019 3:45 am
Not knowing how you're powering the drive, there are two possibilities.
Insufficient 5v power will cause drives like this to go "off-line" when they're spun faster than they have power for. You get a read error, followed by an I/O error, as the operating system tries to deal with the drive as it resets. Usually happens late in the rip, and you can see the rip speed climb until it reaches a certain point, and things go dead.
Errors on the disk, which the drive spends too much time trying to work around, and the operating system pops an I/O error in response.
The first issue will have read errors the move around between rip attempts. The second will have them occur at just about the same point on multiple attempts.
Cleaning usually fixes the second. The first has to be dealt with by either getting sufficient power to the drive, OR slowing done MakeMKV's writing, so that it doesn't make the drive spin over its limit.
Bucky92
Post by Bucky92 » Fri May 24, 2019 11:58 am
Thanks! I tried cleaning the disc and that didn’t help. I will check the speed in makemkv next.
Post by Woodstock » Fri May 24, 2019 1:45 pm
Currently, the only way to slow MakeMKV's writing is to use a slow media (like a USB flash drive) as the target. And the flash drive has to be formatted using either ExFAT or NTFS if you're dealing with anything bigger than 4GB in size.
Grauhaar
Post by Grauhaar » Fri May 24, 2019 3:02 pm
I would say that this is a bad spot on the disc. Can happen, also on brand new discs. The position is around 9.87x.xxx.xxx (bytes counted from the start, in this case approx 9,5GB). Tested it in two different drives (serval discs), same error on nearly the same position. Ordered a new disc and the problem was gone.
Good Luck :)
