I haven't got any UHD discs to test yet but I'll give what you suggested a go first. Thanks for the suggestion.MartyMcNuts wrote: Thu May 23, 2019 2:09 am I take it, you have already tried a UHD disc with that firmware?
I'm pretty sure I have read somewhere that firmware BW50 works. Maybe that was for a BU50N drive. I can't remember.
Anyway, you can use a SATA / USB adapter (you will also need a SATA / slimline ATA adapter) to flash the drive, but you might be better off using SATA and the old Dosflash method to extract that firmware first.
What I would do:
1. Use SATA connection and old Dosflash method to extract firmware BW41 from your drive.
2. Reboot.
3. Use the modified or patched windows flasher to flash the drive using a SATA / USB adapter to 1.00 and see if it works.
Then, if the drive doesn't work with 1.00, then you can use the old Dosflash method to restore your BW41 firmware.
UHD drives
Re: UHD drives
Re: UHD drives
No worries. Yeah, I'd try a UHD disc first, just in case BW41 is actually compatible. You won't know until you try!pegasus21 wrote: Thu May 23, 2019 2:13 amI haven't got any UHD discs to test yet but I'll give what you suggested a go first. Thanks for the suggestion.MartyMcNuts wrote: Thu May 23, 2019 2:09 am I take it, you have already tried a UHD disc with that firmware?
What I would do:
2. Reboot.
Re: UHD drives
Use the DE_LG_BU40N_100.bin that's packaged with the updated flashers these guys have been so awesome to share with us. MakeMKV now prints a log message that implies it's looking for a libre drive when it encounters a drive with the old school firmware on it.So it's DE or MK firmware foe me!
Re: UHD drives
Thank you for confirming that it should work. Now I just need to get a set up that can flash the firmware since the usb adapter doesn't seem to be recognized by the flasher. Probably check if one of my laptops can get it flashed.jonghotti wrote: Thu May 23, 2019 7:50 am Use the DE_LG_BU40N_100.bin that's packaged with the updated flashers these guys have been so awesome to share with us. MakeMKV now prints a log message that implies it's looking for a libre drive when it encounters a drive with the old school firmware on it.So it's DE or MK firmware foe me!
Re: UHD drives
Which fw do you use to flash the BU40N that you sell? And this ASUS flash tool I presume?jonghotti wrote: Thu May 23, 2019 7:50 am Use the DE_LG_BU40N_100.bin that's packaged with the updated flashers these guys have been so awesome to share with us. MakeMKV now prints a log message that implies it's looking for a libre drive when it encounters a drive with the old school firmware on it.So it's DE or MK firmware foe me!
Thanks.
Re: UHD drives
I want to order QXL uhd friendly drive.
I live in Europe.
Can someone help me with that?
I can send money using paypal,
but private message has been disabled.
I have seen on Ebay, that some folks sell uhd friendly drives. If you do,
be sure to checkout firmware version and ratings...
I live in Europe.
Re: UHD drives
There's an entire subforum dedicated to this:mostlife wrote: Fri May 24, 2019 4:02 am I want to order QXL uhd friendly drive.
I live in Europe.
https://www.makemkv.com/forum/viewforum.php?f=20
Gotta do your part and read. Several sellers list detailed contact information in their respective posts.
Re: UHD drives
I was using the original 1.00 but have switched to the 1.00 DE. As the BU40N is an LG drive I'd stick to the LG flasher.maxblack wrote: Thu May 23, 2019 3:09 pmWhich fw do you use to flash the BU40N that you sell? And this ASUS flash tool I presume?jonghotti wrote: Thu May 23, 2019 7:50 am Use the DE_LG_BU40N_100.bin that's packaged with the updated flashers these guys have been so awesome to share with us. MakeMKV now prints a log message that implies it's looking for a libre drive when it encounters a drive with the old school firmware on it.So it's DE or MK firmware foe me!
Thanks.
Re: UHD drives
Alex, you do know that either flasher can flash both LG and ASUS drives (plus other branded clones), don't you?jonghotti wrote: Sat May 25, 2019 3:18 amI was using the original 1.00 but have switched to the 1.00 DE. As the BU40N is an LG drive I'd stick to the LG flasher.maxblack wrote: Thu May 23, 2019 3:09 pmWhich fw do you use to flash the BU40N that you sell? And this ASUS flash tool I presume?jonghotti wrote: Thu May 23, 2019 7:50 am Use the DE_LG_BU40N_100.bin that's packaged with the updated flashers these guys have been so awesome to share with us. MakeMKV now prints a log message that implies it's looking for a libre drive when it encounters a drive with the old school firmware on it.So it's DE or MK firmware foe me!
Thanks.
Re: UHD drives
I do yes, but I still like to "brand match" whenever possible.MartyMcNuts wrote: Sat May 25, 2019 4:18 am Alex, you do know that either flasher can flash both LG and ASUS drives (plus other branded clones), don't you?
Sure wish we had a flasher for the BP50NB40....
Falloutboy
Re: UHD drives
I have an LG Drive which reports the following under MakeMKV.
Product: BD-RE-BH14NS40
Revision: 1.00
Serial Number <Redacted
Firmware date: 2112-06-16 18:23
Bus Encryption flags: 17
Highest AACS version: 64.
Now I have seen my model mentioned and just wanted to make sure I understood things correctly - the revision is the Firmware revision? and if this is the case from what I have seen I should not need to do anything in order to read a UHD disk on this - is that correct or have I gotten something confused despite all my reading?
Revision: 1.00
Re: UHD drives
'Firmware date: 2112-06-16 18:23' indicates a mfgring date prior to ~2015 (svc code NS40, printed on physical label). Old hardware. Incompatible with UHD.Falloutboy wrote: Mon Jun 24, 2019 12:07 pm I have an LG Drive which reports the following under MakeMKV.
Revision: 1.00
Discussion of similar drive/issue:
https://www.makemkv.com/forum/viewtopic ... 832#p58594
Falloutboy
Re: UHD drives
[/quote]'Firmware date: 2112-06-16 18:23' indicates a mfgring date prior to 2015 (svc code NS40, printed on physical label). Old hardware. Incompatible with UHD.
[/quote]
Thanks for the response, upon checking my drive shows July 2012 and does not show the code NS50.... It was worth a shot
[/quote]
Re: UHD drives
It's always safer to ask. There are numerous threads where people have blindly flashed these drives & while recovery is possible, it's a PITA (for those who didn't read up/ask in the 1st place).
