Into the Spider-Verse
misterala
Post by misterala »
Used to MakeMKV getting stuck on scratched and old disks, but this is a brand new copy from Amazon, which plays perfectly fine. When I go to rip it in MakeMKV, it goes through the analysing section and then hangs at a output size of 8.1K no matter how long I leave it. It never actually brings up an error - it just never progresses at all.
Any ideas?
Re: Into the Spider-Verse
Do you have debug logging turned on? There are a lot of errors that don't display if you don't have debug enabled.
misterala
Post by misterala »
Thanks! Have tried again and this is what it's producing. Note, this is just a fraction - the log is generating thousands of debug codes...
005014:0000 Saving 9 titles into directory D:/Plex/Movies/Into the Spider-Verse
001003:0020 DEBUG: Code 0 at f(X:!9Y1LeYU}{\ S:121262026
CCX001: Launching C:\Program Files (x86)\MakeMKV\mmccextr64.exe
CCX001: CCExtractor 0.85, Carlos Fernandez Sanz, Volker Quetschke.
CCX001: Teletext portions taken from Petr Kutalek's telxcc
CCX001: This is a reduced-functionality version optimised for DVD closed captions transcoding.
CCX001: --------------------------------------------------------------------------
CCX001: Reading from standard input
CCX001: Analyzing data in CCExtractor's binary format
CCX001: Sending captions to stdout.
DEBUG: Code 256 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 512 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 768 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 1024 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 1280 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 1536 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 1792 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 2048 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 2304 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 2560 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 2816 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 3072 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 3328 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 3584 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 3840 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 4096 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 4352 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 4608 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 4864 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 5120 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 5376 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 5632 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 5888 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 6144 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 6400 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 6656 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 6912 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 7168 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 7424 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 7680 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 7936 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 8192 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 8448 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 8704 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 8960 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 9216 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 9472 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 9728 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 9984 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 10240 at D`n#H4_P5x]ysv&d[.a:213132652
misterala
Post by misterala »
Right, turns out it will rip if left long enough - it must have got through thousands of those errors and then started to extract.
So for anyone with the same problem: if it doesn't seem to be doing anything, maybe leave it for a few hours...
