Cold Pursuit (U.S.A) PLAYLIST
Steveredrum
Post by Steveredrum » Mon May 13, 2019 6:04 am
Cold Pursuit (Retail U.S.A) PLAYLIST Please anyone - I think it could be [00972.MPLS]
Batiatus
Re: Cold Pursuit (U.S.A) PLAYLIST
Post by Batiatus » Mon May 13, 2019 7:34 am
That is the one I am trying. It's has all the segments in the order that makes sense though when play testing them it seemed like there were still gaps in between a few segments. Only watching it will tell for sure.
hvnphoto
Post by hvnphoto » Mon May 13, 2019 4:01 pm
Playlist 00972.MPLS. I will provide the segment map a little later.
Steveredrum
Post by Steveredrum » Mon May 13, 2019 8:18 pm
hvnphoto wrote: Mon May 13, 2019 4:01 pm Playlist 00972.MPLS. I will provide the segment map a little later.
Thanks for the confirmation
hvnphoto
Post by hvnphoto » Tue May 14, 2019 2:26 am
Title information
Source file name: 00972.mpls
Duration: 1:59:00
Chapters count: 16
Segment count: 15
Segment map: 515,509,506,514,511,504,507,508,501,513,503,502,505,512,510
File name: Cold Pursuit_t389.mkv
bill2468
Post by bill2468 » Tue May 14, 2019 2:17 pm
Can anyone help with the Red Box version. There is no 0972mpls on RB Cold Pursuit.
tobunk
Post by tobunk » Tue May 14, 2019 9:07 pm
bill2468 wrote: Tue May 14, 2019 2:17 pm Can anyone help with the Red Box version. There is no 0972mpls on RB Cold Pursuit.
same.
WAYFLIX
Post by WAYFLIX » Tue May 14, 2019 10:04 pm
tobunk wrote: Tue May 14, 2019 9:07 pm
same.
Filter log method using power DVD on the PC gives me 501 mpls for RB version.
Erazerhed
Post by Erazerhed » Tue May 14, 2019 11:45 pm
So segment maps do not necessarily follow from retail to RB versions? In fact there was not a single RB playlist that started with 515. Thank you! I had saved the designated "main feature".
Urgthock
Post by Urgthock » Tue May 14, 2019 11:50 pm
I am not sure why my copy of MakeMKV correctly "found" the Main Feature playlist for the redbox version of the Cold Pursuit Blu Ray, but it did. Here is the information from the rip.
Title information
Comment: FPL_MainFeature
Source file name: 00299.mpls
Duration: 1:59:00
Chapters count: 16
Segment count: 15
Segment map: 513,509,502,503,510,512,505,508,514,506,504,515,511,501,507
File name: Cold Pursuit-FPL_MainFeature_t00.mkv
Erazerhed
Post by Erazerhed » Wed May 15, 2019 1:22 am
Fortunately a person has 45 hrs to see it sorted out.
Plexman
Post by Plexman » Thu May 16, 2019 3:30 am
WAYFLIX wrote: Tue May 14, 2019 10:04 pm
same.
I've verified that 501 is the MPLS for the Red Box version of Cold Pursuit (USA), by using a process monitor to determine that the segment map is [513,503,502,509,510,505,508,512,514,504,506,501,515,511,507].
rbtf70
Post by rbtf70 » Fri May 17, 2019 12:47 am
Verified the 972.mpsl for the USA Retail. Played the Blu-Ray on the TV synced with 972 on a tablet. 100%! Great job!
1ChiefsDan
Post by 1ChiefsDan » Fri May 17, 2019 11:59 pm
same.
Redbox Blu-ray should be 299
Revilo17
Post by Revilo17 » Sat May 18, 2019 4:45 am
RB 299mpls is messed up. I'm verifying 501 for RB version
