BUG: Can not eject 2nd DVD drive while MakeMKV is running
rcork
#1 Post by rcork » Mon Sep 06, 2010 5:36 pm
I have 2 drives:
1. Optiarc DVD
2. LG BD-ROM
While MakeMKV is running, attempting to eject an audio CD from the Optiarc drive results in the icon disappearing from the desktop but the disc does not eject. If I try to eject via Disk Utility, then it says files are in use and cannot eject. I'm assuming MakeMKV has a lock on some files even though i have not selected that drive in MakeMKV. After i quit MakeMKV then i can go into Disk Utility, choose mount to make the CD icon reappear on the desktop, and then eject the disc as usual.
Here is my log:
Debug log started at Mon Sep  6 17:33:35 2010 , written by MakeMKV v1.5.8 darwin(x86-release)
001005:0000 MakeMKV v1.5.8 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/rob/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL Optiarc DVD RW AD-7240S 1.03" opened in OS access mode.
002010:0000 Optical drive "BD-ROM HL-DT-ST BDDVDRW CH10LS20 1.00" opened in OS access mode.
001003:0020 DEBUG: Code 1073741829 at f'/en*`b3u>-149*tp:121263636
001003:0020 DEBUG: Code 1073741829 at f'/en*`b3u>-149*tp:213130007
002003:0000 Error 'Posix error - Input/output error' occured while reading 'DVD+R-DL Optiarc DVD RW AD-7240S 1.03' at offset '524288'
002003:0000 Error 'Posix error - Input/output error' occured while reading 'DVD+R-DL Optiarc DVD RW AD-7240S 1.03' at offset '1048576'
001003:0020 DEBUG: Code 1073741829 at f'/en*`b3u>-149*tp:213132376
002003:0000 Error 'Posix error - Input/output error' occured while reading 'DVD+R-DL Optiarc DVD RW AD-7240S 1.03' at offset '32768'
001003:0020 DEBUG: Code 0 at M;Jxmda%Ro>*T_N`"tv:29393447
Re: BUG: Can not eject 2nd DVD drive while MakeMKV is runnin
#2 Post by mike admin » Tue Sep 07, 2010 8:07 am
Thanks for reporting. You are right, MakeMKV accesses all drives in order to detect a newly inserted disc. Issue noted.
