Unable to work with Blu-ray discs
at t 2d
Post by at t 2d »
I have been able to open and backup several DVD. My laptop can't read Blu-ray so I purchased an external USB Blu-ray/4k drive. It works fine when working with DVD, but I receive the same error whenever I try to open a Blu-ray. Please see the log below. Each time it tells me that the 30 day evaluation period begins at that time. I plan on purchasing the software, I just want to make sure that it works first.
Thank you in advance for your help. I removed some of what appears to be similar errors in the log due to the limit on the size of forum messages.
MakeMKV v1.14.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\xxxxxxxxx/MakeMKV_log.txt
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at 9feUnk3-Vsu(9Z;UE:213130766
DEBUG: Code 0 at rl(}K"Hk=3WvG?cj-F:121263521
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at rl(}K"Hk=3WvG?cj-F:213131709
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom1'
DEBUG: Code 1 at rl(}K"Hk=3WvG?cj-F:121263521
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom1'
DEBUG: Code 1 at rl(}K"Hk=3WvG?cj-F:213131709
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom1'
DEBUG: Code 2 at rl(}K"Hk=3WvG?cj-F:121263521
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom1'
DEBUG: Code 2 at rl(}K"Hk=3WvG?cj-F:213131709
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom1'
DEBUG: Code 3 at rl(}K"Hk=3WvG?cj-F:121263521
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom1'
DEBUG: Code 3 at rl(}K"Hk=3WvG?cj-F:213131709
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at rl(}K"Hk=3WvG?cj-F:213130904
DEBUG: Code 2 at rl(}K"Hk=3WvG?cj-F:213130904
DEBUG: Code 3 at rl(}K"Hk=3WvG?cj-F:213130904
DEBUG: Code 4 at rl(}K"Hk=3WvG?cj-F:213130904
DEBUG: Code 1 at rl(}K"Hk=3WvG?cj-F:213130904
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at rl(}K"Hk=3WvG?cj-F:213132721
DEBUG: Code 233 at uGDNVJlMPZ3/WZRAC0QcdiEs:0
Downloading latest HK to C:\Users\xxxxxxxxx/.MakeMKV ...
Saved AACS dump file as C:\Users\xxxxxxxxx/.MakeMKV/MKB_v4_LIVE_FREE_DIE_HARD_6D82.tgz
DEBUG: Code 0 at jFJ/sedl|n^h9"'$:29396115
DEBUG: Code 0 at jFJ/sedl|n^h9"'$:213134262
DEBUG: Code 233 at X08Yu9gvd+hLoX2oQmA3godg:0
DEBUG: Code 233 at FjWYgNvhizBVNOakFGYjS83U:0
DEBUG: Code 233 at tNBmkAf301r6G2Tv4LQPXrMn:0
DEBUG: Code 233 at GKUsiTvHUpdxqpXc88YUGyNi:0
DEBUG: Code 233 at mdMgx3nUrDnEexcNW3YRJ+AH:0
DEBUG: Code 233 at uXWHah2b0Ues4HPqfojf3KTu:0
DEBUG: Code 233 at QYJUr+TNv2VjJOn944ZRJKVP:0
DEBUG: Code 233 at /6YnTaSOjMXfnNx/KfrU11so:0
DEBUG: Code 233 at 6xZvk73E6Vhgkq6hPKbLT1bS:0
