usb to sata adapters?
thetoad
Post by thetoad »
Anyone know of any usb to sata adapters (externally provided power most likely) that work with desktop optical drives?
I got a cheap one from ebay that has a 12v input and it works with my desktop sata hard disks (so its not a loss, and for under $1 after ebay coupon was willing to risk it), but doesn't seem to work with my optical drives (i.e. the drive powers on, I can eject the tray...) but its never detected by either windows or linux. wondering if its due to usb not providing enough amps on the 5v rail.
thoughts?
jonghotti
Re: usb to sata adapters?
Post by jonghotti »
The Sharkoon USB to SATA works for me also.
Unitek Y-1034 works great for me!
jonghotti
Post by jonghotti »
tyeeman
Post by tyeeman »
Does the WEme do the firmware flash ok? Lots of complaints for the Unitek on amazon. Hmm...
tyeeman wrote: Wed May 22, 2019 2:26 am Does the WEme do the firmware flash ok? Lots of complaints for the Unitek on amazon. Hmm...
I have 2 x Unitek Y-1034 and have flashed a heck of a lot of drives with them and have had absolutely no issues at all.
jonghotti
Post by jonghotti »
fishman
Post by fishman »
Sorry, I had to re-register, I wasn't getting the email address change. Anyway, I may try one of each even though they look identical. I agree about usb, why don't all HDs and ODDs have USB only connectors now? Sooner or later it will change but to what?
fishman
Post by fishman »
Marty -
The Unitek Y-1034 does not come with a power cable, how do you power up your ODDs?
BlueMac77
Post by BlueMac77 »
MartyMcNuts wrote: Wed May 22, 2019 3:03 am
Hi MartyMcNuts. To clarify, the Unitek Y-1034 USB 3.0 to Sata is the same model in this page? https://www.amazon.com/Unitek-Adapter-C ... B06WWLCYC3
And you can flash any 4K uhd friendly drive using this Unitek Y-1034?
jonghotti
Post by jonghotti »
BlueMac77
Post by BlueMac77 »
Thanks Alex. I'll let you know if I decide to get one from you. :)
BlueMac77 wrote: Wed May 22, 2019 5:34 am
That doesn't look like mine. The link you provided is for the Y-1099. Perhaps this is a newer model?
Mine look like this:
https://www.msy.com.au/vic/geelong/pc-a ... cable.html
It seems to be getting harder and harder to get. I think it may have been discontinued.
I'm also tempted to purchase a Y-3322 or Y3324 to try.
Unitek Y-3322 https://www.amazon.com/dp/B00EHDTRJ6/ref=emc_b_5_t
Unitek Y-3324 https://www.amazon.com/dp/B01NAUIA6G/ref=emc_b_5_t
BlueMac77
Post by BlueMac77 »
Thanks MartyMcNuts for the confirmation. I normally read first the buyers' reviews before making purchases. Like the UGreen USB3 to eSATA doesn't work with optical drives and only works on HDs or SSDs.
