Error 'Scsi error - MEDIUM ERROR:1090'
brittq
Post by brittq » Sun Jan 29, 2012 8:11 pm
Ripping Mesrine: Part2: Public Enemy #1
Any ideas why I get this error?
MakeMKV v1.7.1 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in DASPI v1.3 mode.
Optical drive "HD-DVD-ROM HL-DT-ST BDDVDRW GGC-H20L 1.03" opened in DASPI v1.3 mode.
Evaluation version, 8 day(s) out of 30 remaining
File 00000.m2ts was added as title #0
File 00004.mpls was added as title #1
Title #00008.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00011.m2ts was added as title #2
Saving 1 titles into directory /Users/brittonquinn/Desktop
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '2949445632'
Failed to save title 0 to file /Users/brittonquinn/Desktop/title00.mkv
0 titles saved, 1 failed
Re: Error 'Scsi error - MEDIUM ERROR:1090'
Post by mike admin » Tue Jan 31, 2012 7:20 am
A physically damaged disc.
Tymooo
Post by Tymooo » Sun May 12, 2019 7:03 pm
Old topic, same issue. I don't think the problem is physical damage though.
I'm currently ripping a brand new bought box from the tv-show Community and got the same issue at season 3.
But it's even weirder because I wanted to rip 6 episodes from that disc and it ripped all episodes except the first and the last.
I also tried ripping them manually but it always failed at the very end...
When I read that it'd probably be caused by physical damage I tried to watch it normally on my tv; no issues there with both episodes.
So as I said: brand new and no issues while playing.
Any other idea what might cause the problem?
Edit: I apologize; obviously I'm the kind of person who posts into a thread first and then reads through the basic FAQ... :oops:
After reading the basic FAQ regarding reading errors (https://www.makemkv.com/forum/viewtopic.php?f=8&t=15055) I carefully cleaned the dvd disc although it was brand new. But now it worked perfectly fine, so try this first in case you're experiencing the same problem. :wink:
