Black Hawk Down
Swaps
Black Hawk Down
Post by Swaps » Sat May 11, 2019 1:24 am
Disc decrypts fine, but there are 4 titles. Anyone know which one is correct? Thanks
Re: Black Hawk Down
Post by MartyMcNuts » Sat May 11, 2019 2:50 am
Extended Version = 503.mpls
Theatrical Version = 501.mpls
Swaps
Re: Black Hawk Down
Post by Swaps » Sat May 11, 2019 2:14 pm
kingston12
Re: Black Hawk Down
Post by kingston12 » Wed May 29, 2019 2:36 pm
I think I must have a bad copy of this.
I have tried ripping both files several times and it gets to about 65% complete and the read speed collapses from 6.0x to about 3.5x and then fails because of a SCSI error.
I've tried on my other drive and it won't work at all.
Hopefully another copy will sort it out.
jayper
Re: Black Hawk Down
Post by jayper » Thu May 30, 2019 3:53 pm
Same here. I picked up a second copy, and still no dice. I can't tell if it is bad authoring or the UHD disc keeps getting scratched because it was stacked on top of the standard BR disc. It's a bummer.
Re: Black Hawk Down
Post by MartyMcNuts » Fri May 31, 2019 12:04 am
@jayper, @ kingston12,
Guys, try cleaning your discs with a microfibre cloth, yes, even if they already look spotless. Also, if you haven't already, try doing a FULL FOLDER backup of the disc.
jayper
Re: Black Hawk Down
Post by jayper » Fri May 31, 2019 6:59 pm
I appreciate the tip. I've done that with both discs, a few times. Unfortunately, it doesn't seem to have helped at all.
Esch30
Re: Black Hawk Down
Post by Esch30 » Sat Jun 01, 2019 2:22 am
This was actually the first disc that my ASUS drive could not rip. I tried cleaning the disc, performing a full folder backup, etc. and nothing worked. The read speed slowed at the same point each time and ultimately failed.
I happened to recently install an LG BU40N in an old laptop and gave it a try with that. It worked on the very first attempt. I've read on here that some discs just don't jive with some drives, and I found that to be the case with this disc.
Wardy
Re: Black Hawk Down
Post by Wardy » Tue Jun 04, 2019 9:35 am
There is definitely something funky with this disc and Asus drives, I've had two copies of the UK disc that have failed to either read at all, thrown scsi errors or failed part way through a rip, using two identical Asus BW-16D1HT with firmware 3.01, I also tried 3.10MK to no avail, both with Makemkv and DVDfab.
I'm returning the disc to Amazon.
kingston12
Re: Black Hawk Down
Post by kingston12 » Tue Jun 04, 2019 3:46 pm
I eventually managed to get this working. The second copy of the disc wouldn't work on either of my LG drives to start with, but then when I swapped the desktop drive to the laptop it worked fine.
jayper
Re: Black Hawk Down
Post by jayper » Wed Jun 05, 2019 1:10 am
Yup. This is a weird one. I have tried two different copies, cleaned both with two different drives: an LG and ASUS.
Going to try a third disc tonight. Fingers crossed. This is the first disc I have had an actual issue with after cleaning. I'm convinced it is the way they were packaged: UHD stacked on top of the standard BR disc. I think this led to more scratching, can't really prove that though.
CJ32601@yahoo.com
Re: Black Hawk Down
Post by CJ32601@yahoo.com » Fri Jun 14, 2019 8:21 pm
Mine isn’t ripping either with my Asus drive. Pretty bummed. First time I couldn’t get a 4K disc to rip. Maybe I’ll try swapping the movie out for a fresh one.
jayper
Re: Black Hawk Down
Post by jayper » Fri Jun 14, 2019 9:19 pm
Best of luck! Third time was the charm for me.
Drivinfast247
Re: Black Hawk Down
Post by Drivinfast247 » Wed Jul 17, 2019 3:21 pm
Same issue here. It fails to rip and throws SCSI and debug codes. Brand new disc right from the package.
Re: Black Hawk Down
Post by MartyMcNuts » Thu Jul 18, 2019 12:50 am
Give your disc a good clean (even if it is brand spanking new and appears spotless!) then try again.
