Rolling Stones - Biggest Bang
				jbryngelson
I have tried to make a MKV copy to my HD a couple times, and each time, it completes with no errors, but when I play the file, it only gives me audio, and no video.  Other BluRay discs are properly converted.  Any suggestions?
				setarip_old
Re: Rolling Stones - Biggest Bang
Hi!
1) What are you using for playback?
2) Load the .MKV into tsMuxeR - What is the video codec?
				jbryngelson
I am playing the file with Plex (www.plexapp.com) on my mac mini.
I will try to play the file on a PC with either PowerDVD or VLC and see what happens.
Not sure of the Codec, but let me test.
