Download and install the previous version
marknicolai192
Post by marknicolai192 »
Hi all,
I have used the newest version a few times, I downloaded it just a few days ago, as I had not done any ripping over the summer. After one successful rip, and two rips that errorred out, tonight when I tried to open MakeMKV, I got the message that my version was old and that I needed to download the new version. I attempted to do so three times, but have still gotten the same message when I attempt to open the program. I have even tried to download and install the previous version, per a recommendation from the message board, but I still get the same message.
Any assistance would be greatly appreciated.
Thanks alots
Re: Download and install the previous version
https://makemkv.com/download/old/
Won't fix the problem; the issue is that the current version has a key that expired in March. You have to put the CURRENT beta key in.
To do that, you need to set your system DATE back to late March, start MakeMKV, then you can enter the new key. The system date can be reset to current as soon as MakeMKV is running.
