Date Night BD+ error
Anyone else having problems backing up Date Night?
setarip_old
Re: Date Night BD+ error
HI!
Perhaps you can be "a bit" more specific? :
1) Are you having a problem when trying to do a full disc backup or .MKVs?
2) What is the problem?
I tried to backup the movie only and when I tried to open the disc, I got the following message.
MakeMKV v1.5.7 beta darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in OS access mode.
Optical drive "BD-ROM PLEXTOR BDDVDR PX-B310U 1.07" opened in OS access mode.
Loaded 26 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
BD+ dump directory is not set in preferences, BD+ dump not saved
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
setarip_old
Click on the link provided in the message that you've now posted. There you'll find the information you need to complete the BD+ portion of your installation of MakeMKV...
I am having the same problem and I dl the referenced svq file and it still gives the error
update
installing 1.5.8 solved the problem here......
I'm also unable to backup Date Night.
Get the same error message as reported in this thread.
I've sent the dump the the specified address and hope someone can help.
