I am on a mac with Windows 7 in virtualbox. I have the LG WH16NS40. MakeMKV is recognizing the drive and confirms that it is possible to use LibreDrive with patched firmware. When I try to run the flasher tool I get the error: Valid ATAPI device can not be found!!! F/W model is BD-RE BH14NS40.
What am I doing wrong?
Flasher tool error
Re: Flasher tool error
could be a few thingsmbautsch wrote: Tue May 07, 2019 10:23 pm I am on a mac with Windows 7 in virtualbox. I have the LG WH16NS40. MakeMKV is recognizing the drive and confirms that it is possible to use LibreDrive with patched firmware. When I try to run the flasher tool I get the error: Valid ATAPI device can not be found!!! F/W model is BD-RE BH14NS40.
1. drive is not fully passed through to vm
2. usb controller drive is connected to is not fully passed through to vm
3. the drive enclosure/usb to sata adapter does not support the flashing atapi commands.
what drive adapter are you using?
I have it in the drive bay connected directly to the sata cable. It’s mounting disks in windows.
the sata controller needs to be fully passed throughmbautsch wrote: Wed May 08, 2019 1:35 am I have it in the drive bay connected directly to the sata cable. It’s mounting disks in windows.
might be better to just boot into bootcamp or off a usb windows pe if that is possible on a mac no idea how locked down they are
I found a PC to hook it up to and it worked. Getting ready to install it inside the Mac Pro Tower.
