Firmware downgrade using official (patched) flasher, the "Ultra hax0r guide"
Locked
Re: Firmware downgrade using official (patched) flasher, the
#151 Post by Billycar11 » Wed Apr 17, 2019 11:42 am
spl147 wrote: Wed Apr 17, 2019 11:25 am
mcnugget wrote:
Billycar11 wrote: Wed Feb 06, 2019 12:37 am
Included in this zip is the following firmware:
WH16NS60_1.00
https://drive.google.com/file/d/1k2h5In ... sp=sharing
MD5: 9C83D4E39F34B6B17E7CD273AF522887
SHA-256: 3D9B0EDCA7058028A6DB5590A0EB4C42F0B729A5EFC042033264B1346874FED8
I know there's only been 1000 confirmation requests, but the DE WH16NS60_1.00 from the link quoted (pg 1 of thread), is ideal for a newly purchased NS50 WH14NS40 via the Marty Mcnuts GUI app?
Thanks for all your awesome work everyone
TOO LATE! jumped blind, looks awesome!
You should of flashed the MK NS60 1.01 firmware
Sent from my iPhone Xs Max using Tapatalk Pro
1.00 has compatibility advantages
Re: Firmware downgrade using official (patched) flasher, the "Ultra hax0r guide"
#152 Post by Billycar11 » Wed Apr 24, 2019 11:06 pm
Buffalo BRUHD-PU3 BU10 DE added
Thanks to
flashback8 wrote:
let me know how it works i tested it on a BU40N with BU10 and all seemed good but slower than BU40N 1.00
flashback8
#153 Post by flashback8 » Wed Apr 24, 2019 11:08 pm
Just FYI, I just received a new BRUHD-PU3 with BU11 pre-installed. I made my own DE version of BU10 right around the time this post came up. The BU11-installed PU3 works fine with the DE version of BU10. :) (I assume Mike will generate an MK version at some point.) I'll try the BR40N FW on the PU3 at some point and see how it goes. In the meantime, this drive is good to go.
Thanks to Billycar11 for making all this happen, and for helping me fill in some gaps.
Youtube
#154 Post by Youtube » Sat May 04, 2019 3:11 am
flashback8 wrote: Wed Apr 24, 2019 11:08 pm Just FYI, I just received a new BRUHD-PU3 with BU11 pre-installed. I made my own DE version of BU10 right around the time this post came up. The BU11-installed PU3 works fine with the DE version of BU10. :) (I assume Mike will generate an MK version at some point.) I'll try the BR40N FW on the PU3 at some point and see how it goes. In the meantime, this drive is good to go.
Hi,mate.i am using the BRUHD-PU3 with BU11,and i dont know how to Downgrade to BU10 ,can you teach me?many thanks!
flashback8
#155 Post by flashback8 » Mon May 06, 2019 6:59 pm
Youtube wrote: Sat May 04, 2019 3:11 am
Hi. Please follow the directions in this post.
#156 Post by Billycar11 » Mon May 06, 2019 7:27 pm
Here is a how to video I made
https://www.youtube.com/watch?v=Yfpf6HoMMis
BriBo
#157 Post by BriBo » Tue May 07, 2019 2:21 pm
I'm new to this forum and have a LG WH16NS40 drive, which came with the 1.03 firmware installed. I've been reading this thread and have watched the YouTube video explaining how to use the patched flasher tool. The problem is I can't get the file to download from ZippyShare. Clicking the Download Now button gives you everything but the actual file you're trying to download. Is there another source for this tool? :x
Youtube
#158 Post by Youtube » Wed May 08, 2019 5:28 am
BriBo wrote: Tue May 07, 2019 2:21 pm I'm new to this forum and have a LG WH16NS40 drive, which came with the 1.03 firmware installed. I've been reading this thread and have watched the YouTube video explaining how to use the patched flasher tool. The problem is I can't get the file to download from ZippyShare. Clicking the Download Now button gives you everything but the actual file you're trying to download. Is there another source for this tool? :x
which link,i can downlaod it and upload it to google drive amd then give you link.
Youtube
#159 Post by Youtube » Wed May 08, 2019 5:29 am
flashback8 wrote: Mon May 06, 2019 6:59 pm
It works.thanks a lot.Mate.
#160 Post by Billycar11 » Wed May 08, 2019 4:19 pm
The link on my YouTube video is not on zippyshare that is aids that's why I didn't use it
It is on Google drive see post here and my YouTube video description
https://www.makemkv.com/forum/viewtopic ... 873#p70284
bgalakazam
#161 Post by bgalakazam » Fri May 10, 2019 7:35 pm
Thank you, worked perfectly. Downgraded WH16NS40 without issues 1.03 -> 1.02.
Sony X700 -> Onkyo TX-RZ830 -> LG C8
#162 Post by Coopervid » Sun May 12, 2019 9:05 pm
@nj54567,
There is updated firmware that will fix the problem. No -of course it will not compromise the enclosure. Just make it better.
easyrhino
#163 Post by easyrhino » Wed May 29, 2019 12:06 am
just wanted to log in and say that, as a noob, I used the zip file at the bottom of the third post (provided by billycar11) and it worked great on my wh14ns40.
It was quite quick and easier than expected.
loadnabox
#164 Post by loadnabox » Sat Jun 15, 2019 2:18 am
I'm getting the notorious "Write DRAM NG" error
I just purchased a LG WH14NS40_NS50 drive with firmware v1.03 on it. Sadly my old drive of the exact same model with FW 1.01 died on me :(
I'm using the patched LG firmware updated provided earlier in this thread from the google drive files. I've tried using both the 1.00 and 1.02 firmware included in the zip file and have confirmed the hex code is correct.
What am I doing wrong here? Pretty bummed right now
#165 Post by d00zah » Sat Jun 15, 2019 3:01 am
loadnabox wrote: Sat Jun 15, 2019 2:18 am I'm getting the notorious "Write DRAM NG" error
Try one of the alternate flash tools & look for an 'MK' version of your drive's FW.
Suggested reading...
viewtopic.php?f=16&t=19634
Locked
