Redbox Extras Missing!
swampdaddy
Post by swampdaddy »
I've noticed that two recent RB rentals do not contain the usual bonus or extras media such as behind the scenes featurettes. The first movie I noticed this with was Serenity (2019) and Glass (2019). Have any of you noticed this?
BTW I just noticed that Glass (2019) does contain some extras on the disk but my Sony Playstation BluRay player did not show the extras on the interface. Have you seen this before?
Also, I usually note the name of each extra and the runtime so that I can properly name things after the rip so in this case I'm not sure what to name things since I cannot see the extras while playing the BD. I'm sure I'm doing this the hardest way possible. Thoughts on a better workflow?
Thanks,
Robert
swampdaddy
Re: Redbox Extras Missing!
Here are the files I copied... some are obvious like "DS" means deleted scene but what are others such as "...CMC..."?
Is there a way to delete a post?
Screenshot 2019-05-05 23.18.20.png (957.52 KiB) Viewed 6229 times
swampdaddy
Okay ignore what I said about Glass... I see the extras now. The main menu does not show the Bonus menu button.... you have to click "Menu" then you get to the usual full featured menu.... However, Serenity did not have the files and I'm quite sure the bonus content was not present on the RB disc.
