[FEATURE REQUEST] Checkbox to enable / disable the default flag of audio and subtitle
mgutt
I know there are several options avaiable to change this setting, but sometimes I like to change it on a single dvd and by that I need to use an additional tool.
- Contact:
Re: [FEATURE REQUEST] Checkbox to enable / disable the default flag of audio and subtitle
No, you can just set is as default manually (on right pane)
mgutt
Ah ok, the dropdown changes after selecting a track. Thanks.
