Burn 4K ISO to non-4K blu-ray disc
dvdplayer
Post by dvdplayer »
Hi all,
My apologies if this question has already been answered (I don't believe it has).
My question is, am I able to burn a 24.3GB 4K movie ISO to a 25GB non-4K bluray disc and play it on a non-4K bluray player?
Yes I know its a stupid question, I'm just curious if anyone has attempted this.
Thank you.
Re: Burn 4K ISO to non-4K blu-ray disc
MakeMKV has nothing to do with BURNING disks. That is up to whatever disk authoring software you obtain.
MakeMKV will not "shrink" the video to fit.
dvdplayer wrote: Sun May 05, 2019 5:52 am Hi all,
Thank you.
I would assume it won't play on a non-4k player as again, I assume, the player would not support HEVC.
You could try to re-encode all video files as x264 then create a new iso or just find a software than can rip/convert a UHD to BD.
Grauhaar
Post by Grauhaar »
Not possible! Blu-ray players do not support the HEVC (H.265) Video codec. Re-econding of the video part to H.264 must be done within the M2TS stream files, I think there is no tool available to do this. An other problem can be (not sure) different structures, flags, features etc. between normal Blu-rays and 4K Blu-rays.
Good Luck :)
dvdplayer
Post by dvdplayer »
Thanks guys,
From my understanding it's the codec that sets them apart not the discs.
So this means that non-4k discs can be used for 4k content as long as there is space, but only playable on a 4k player.
Grauhaar wrote: Mon May 06, 2019 6:12 am Not possible! Blu-ray players do not support the HEVC (H.265) Video codec. Re-econding of the video part to H.264 must be done within the M2TS stream files, I think there is no tool available to do this. An other problem can be (not sure) different structures, flags, features etc. between normal Blu-rays and 4K Blu-rays.
DVDFab has a "UHD to Blu-Ray" option. You can save as folder or iso.
Grauhaar
Post by Grauhaar »
Ah, buy a UHD disc and need to play it in an Blu-ray player. Crazy World :shock: Why not in an DVD player?
Good Luck :)
