Indochine will not open
OrvilleP
Post by OrvilleP » Tue Aug 31, 2010 4:43 pm
MakeMKV v1.5.8 win(x64-release) started
Cant't locate a cell for VTS 1 TTN 1 PGCN 1 PGN 29
setarip_old
Re: Indochine will not open
Post by setarip_old » Tue Aug 31, 2010 8:23 pm
Hi!
Does the original, commercial DVD play on the same system?
Post by mike admin » Wed Sep 01, 2010 8:32 am
Please send the log and IFO files per http://www.makemkv.com/faq/item/8/catid/6
OrvilleP
Post by OrvilleP » Sat Sep 04, 2010 11:48 am
Setarip_old,
Thank you again for responding.
Indochine is a purchased, commercial standard DVD the plays perfectly on my computer running VLC Player. The log file follows and the zip of two IFO files is attached.
Thank you so much for the attention.
Sterling Lindsey
Debug logging enabled, log will be saved as C:\Users\Lindsey/MakeMKV_log.txt
DEBUG: Code 0 at cQ?br;UbG! K|;rHy:29393976
OrvilleP
Post by OrvilleP » Sun Sep 12, 2010 10:29 am
Setarip_old,
Now that I've discovered that C:\Users\Lindsey\MakeMKV_log.txt is revealed only on my MediaClient (Win 7 64-bit) system would you please tell me why Indochine (DVD) cannot be opened by MakeMKV? Here is MakeMKV_log.txt for Indochine:
Debug log started at Sat Sep 11 13:35:53 2010 , written by MakeMKV v1.5.8 win(x64-release)
001005:0000 MakeMKV v1.5.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Lindsey/MakeMKV_log.txt
003010:0000 Cant't locate a cell for VTS 1 TTN 1 PGCN 1 PGN 29
001003:0020 DEBUG: Code 0 at cQ?br;UbG! K|;rHy:29393976
setarip_old
Post by setarip_old » Sun Sep 12, 2010 8:39 pm
I'm afraid I lack the knowledge to interpret the "Debug logs".
I'm sure that "mike admin" will get to it...
Post by mike admin » Tue Sep 14, 2010 7:30 am
For some reasons zip file can't be downloaded. Could you please send it to support@makemkv.com ?
OrvilleP
Post by OrvilleP » Tue Sep 14, 2010 2:05 pm
Mike Admin,
The zip of Indochine is attached.
Would you also please tell me why when I run MakeMKV on my 3800Client (Vista 64-bit) system the file MakeMKV_log.txt does not appear, anywhere. But when I do the same on my MediaClient (Win 7 64-bit) system it does appear in C:Users\Lindsey?
Thanks.
Sterling Lindsey
OrvilleP
Post by OrvilleP » Thu Sep 23, 2010 5:27 pm
Setarip_old,
MakeMKV 1.6.0 will rip DVD Indochine, mostly - HURRAH!. The front end of the DVD, including the 'Choices screen' is chopped off when the MKV is played using VLC 1.1.4. This is compared to playing the disc itself with PowerDVD 9 Ultra. The good news is that DVD Indochine was mostly ripped whereas the previous version produced nothing because it couldn't open the disc. The log file is the first attachment and the snip of collection of rip files is the second attachment.
Sterling Lindsey
