Asus BW-16D1HT 3.03
bobwalton
Re: Asus BW-16D1HT 3.03
Post by bobwalton »
I did a Windows refresh install with same result. So, makemkv is the only thing installed. This is on Windows 10. Could it be a router issue? Do I need a port opened?
Post by SamuriHL »
That makes no sense. Are you 100% sure you went into MakeMKV preferences and the Allow contacting web server for updates checkbox is checked?
Sirius B
Post by Sirius B »
MartyMcNuts wrote: Sun Mar 17, 2019 9:50 pm
mfraz74 wrote: Sun Mar 17, 2019 9:16 pm What software other than WinPE do I need to upgrade to MK 3.03?
The ASUS windows flasher + firmware
viewtopic.php?f=16&t=18933
and/or the MK firmware (see previous post from SamuriHL) if you want to stay on 3.03 firmware.
Fantastic. Tried it but the update failed on both the 3.01 & 3.02 bin file with the error: Updating failure #4. Re-read the boards & copied over Mikes' firmware update for the drive. Re-ran it & all ok.
Firmware version: 3.10
Have been using MKV for some time.
You guys rock. Many thanks.
BLKMGK
Post by BLKMGK »
I've been using this drive quite awhile and only just noticed the Libredrive stuff coming up lol. I came looking to learn about it and the unrestricted read which I understand isn't yet resolved. I'm currently running firmware 3.00 and see comments about custom firmware. Is there any real pressing need for me to move off of 3.0 to say 3.1 and patch it? So far most discs seem to be no issue although I did have issue with one that required a few attempts <shrug>. Just curious :)
spl147
Post by spl147 »
BLKMGK wrote: Wed May 01, 2019 9:50 pm I've been using this drive quite awhile and only just noticed the Libredrive stuff coming up lol. I came looking to learn about it and the unrestricted read which I understand isn't yet resolved. I'm currently running firmware 3.00 and see comments about custom firmware. Is there any real pressing need for me to move off of 3.0 to say 3.1 and patch it? So far most discs seem to be no issue although I did have issue with one that required a few attempts <shrug>. Just curious :)
you should install the MK 3.10 Patched firmware from the libredrive firmware pack
Drakuhl
Post by Drakuhl »
I just got my Asus BW-16D1HT 3.03 today, installed it in my PC, used the new Flasher to update it to the 3.10 MK firmware (from the March 19 pack) and MakeMKV still does not show the Libredrive functionality in the info field:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: [redacted]
Bus encryption flags: 1F
Is there an additional step I missed? I have not yet inserted a UHD disk as I am planning to get my first ones after I get this to work!
Post by mike admin »
Drakuhl wrote: Fri May 03, 2019 10:16 pm Is there an additional step I missed? I have not yet inserted a UHD disk as I am planning to get my first ones after I get this to work!
You need to make sure that MakeMKV can download updates, or you have to download the latest SDF.bin manually.
Drakuhl wrote: Fri May 03, 2019 10:16 pm I just got my Asus BW-16D1HT 3.03 today, installed it in my PC, used the new Flasher to update it to the 3.10 MK firmware (from the March 19 pack) and MakeMKV still does not show the Libredrive functionality in the info field:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
open a bluray disk and then the sdf will download and libredrive will activate
spl147
Post by spl147 »
mike admin wrote: Fri May 03, 2019 10:25 pm
where do we get the SDF.bin from?
jerryfudd81
Post by jerryfudd81 »
spl147 wrote: Sun May 05, 2019 1:44 pm
I was curious too but a quick Google said http://www.makemkv.com/svq/sdf.bin and just stick it in the makemkv dir....
jerryfudd81 wrote: Sun May 05, 2019 2:33 pm
Just put a blu ray or UHD in the drive. MakeMKV will then download the sdf and libredrive info should appear.
Laithan
Post by Laithan »
I had the exact same issue. The issue turned out to be a firewall rule on the router, once I was able to download the updates Libre worked right away and I was able to successfully rip a UHD. I also thought it was due to using an external USB 3.0 enclosure (it wasn't). I hooked the drive up to my eSata port (first time I found a real use for that port lol) and Libre mode didn't work that way either, the problem was definitely the need for the updates to download.
See this related post also
https://www.makemkv.com/forum/viewtopic ... =1&t=17848
aaronwt
Post by aaronwt »
I used the old method from Spring 2018 to upgrade my Asus BW-16D1HT to be UHD friendly. I did two drives in Spring 2018 and one in Summer 2018.
All three drives have been rock solid with reading my UHD BD titles. I've ripped over 225 UHD BD titles with them so far.
Is there any reason for me to upgrade with this newer method to the newer firmware versions?
63TB unRAID1-49TB unRAID2-76TB unRAID3-56TB unRAID4-50TB unRAID5-50TB unRAID6-56TB unRAID7
aaronwt wrote: Fri Aug 02, 2019 10:48 pm I used the old method from Spring 2018 to upgrade my Asus BW-16D1HT to be UHD friendly. I did two drives in Spring 2018 and one in Summer 2018.
No it's the same firmware just an easier was to flash them
aaronwt
Post by aaronwt »
