Captain America - Libredrive compatibility?
extranet
#1 Post by extranet » Fri Apr 26, 2019 12:06 pm
Hi
I have the ASUS 161-BDT f/w version 3.0.1 and I have been able to rip many discs but the new Captain America discs are asking for LibreDrive compatibility. My drive was already downgraded to a UHD friendly firmware so why this?
Re: Captain America - Libredrive compatibility?
#2 Post by SamuriHL » Fri Apr 26, 2019 12:18 pm
What does "asking for libredrive" mean?
Sent from my Pixel XL using Tapatalk
extranet
#3 Post by extranet » Fri Apr 26, 2019 1:36 pm
"Libredrive compatible drive is required to read this disk"
#4 Post by SamuriHL » Fri Apr 26, 2019 2:31 pm
And you have allow online checked in the settings? It might help to see a screen shot of makemkv showing the info for your drive. Something isn't right there.
extranet
#5 Post by extranet » Fri Apr 26, 2019 2:49 pm
I have read the forum pages and apparently there is a patch but what I don't know is if I need it. If I do then I am not able to patch my drive because it is connected via USB/SATA.
#6 Post by SamuriHL » Fri Apr 26, 2019 3:14 pm
No. If it's 3.01 then you don't need to flash anything. That's why I want to see what makemkv says about the drive.
extranet
#7 Post by extranet » Fri Apr 26, 2019 3:31 pm
I posted the exact message.
extranet
#8 Post by extranet » Fri Apr 26, 2019 3:38 pm
OK ignore this. I've just checked a disk I ripped before and it gets the same error. Thanks for trying to help.
extranet
#9 Post by extranet » Fri Apr 26, 2019 3:50 pm
Actually the story is a little weirder. It started working for one of my older disks but not this one until after I used a different account on my PC. Even then it only worked after I manually added the hashed keys. After I did that it kind of reset and started working for this disk. I'm sure I'm missing something here.
Thanks again :)
#10 Post by SamuriHL » Fri Apr 26, 2019 4:44 pm
Did you check the preferences I told you to look at? Specifically the Allow contacting web server... setting MUST be checked and there can't be anything blocking the connection like a firewall. Hashed keys are no longer needed. They are downloaded from MakeMKV's server.
extranet
#11 Post by extranet » Fri Apr 26, 2019 7:29 pm
The preferences were never the issue since I don't change them. For whatever reason the hashed keys were not getting downloaded but finally they downloaded even though I didn't make any changes to the preferences.As I said, it's all a little weird and I may have missed something but everything is working now.
Thanks again.
#12 Post by SamuriHL » Fri Apr 26, 2019 8:19 pm
Could have been something on the system blocking it or who knows what. As long as it's working now you're good.
extranet
#13 Post by extranet » Sat Apr 27, 2019 1:57 pm
I'm beginning to think that it might have been my antivirus software which seems to run a little differently on my Admin account than it does on my non Admin one.
#14 Post by SamuriHL » Sat Apr 27, 2019 2:58 pm
Very possible indeed. Anything that would block the connection MakeMKV makes to download the LibreDrive support and the new hashed keys would cause the behavior you saw.
spl147
#15 Post by spl147 » Tue Apr 30, 2019 11:38 am
Hi
im assuming your drive is a ASUS 16D1HT and not a 161-BDT?
the staying on 3.01 times are way way over, you need to keep up, LOL
the 16D1HT Should be Flashed to MK Firmware 3.10
