Playback too fast
Playback too fast
Several times, I've ripped a Blu-ray disk with all seeming to go well. When I play back the file, it plays at 2x speed. I've tried converting the file to a .mpeg4 but the playback is still fast. Any suggestions? Never have this problem with standard discs.
Re: Playback too fast
What is a "Standard disc" ?
Cause of Speed trouble can be a wrong mastered disc or a bad playing software. But without more details ... the cristal ball have no answers.
Good Luck
what are you playing back in?
I had this happen with blu-rays that had mono PCM tracks.steveneec wrote: ↑Fri Apr 26, 2019 12:35 amSeveral times, I've ripped a Blu-ray disk with all seeming to go well. When I play back the file, it plays at 2x speed. I've tried converting the file to a .mpeg4 but the playback is still fast. Any suggestions? Never have this problem with standard discs.
I got them working by converting the audio to stereo flac.
http://forum.zidoo.tv/index.php?threads ... post-83756
Just got mine fixed.
Use mkvtoolnix to save the mono pcm from the .mkv as a .mka file.
Use Pazera audio extractor to convert and save the .mka as stereo .flac.
Use mkvtoonix to combine the .flac and original .mkv file as a new file. Deselect the mono pcm in the original .mkv when you do this.
Mkv with the stereo .flac audio plays at the correct speed.
