PeterMac
#121 Post by PeterMac » Wed Apr 24, 2019 11:51 pm
MartyMcNuts wrote: Sun Feb 17, 2019 3:30 am Included with the ASUS Flasher, is the 'DE' UHD friendly firmwares we are currently using with the LG Flasher tool.
What does it mean this "DE" ?
#122 Post by SamuriHL » Thu Apr 25, 2019 2:51 am
Downgrade Enabled. Allowing you to downgrade a drive to a previous version.
PeterMac
#123 Post by PeterMac » Thu Apr 25, 2019 9:35 am
Hehe thanks for informations, I thought DE (Deutsh) language firmware :lol:
Edit
@MartyMcNuts - Does it secure to use modifier flasher to downgrade without doing dump backup current firmware ?
Does your included firmware for Asus ver 3.02 different from orginal "clean" one ?
PeterMac
#124 Post by PeterMac » Mon Apr 29, 2019 7:01 pm
I just buy Asus BW-16D1HT, install drive, check firmware and it came with 3.03, I run Modified reflasher select DE 3.02 firmware hit START and drive open tray but nothing more happen, no any progress bar on screen, nothing, I wait more and close reflasher and close tray manually.
After that drive worked fine and shows 3.02 firmware, but I decided to run reflasher again and this time reflasher open tray, shows progress bar, and suscessfull information window and closed tray itself.
How do you think, everything now is correct ? I do not damage drive in some way doing twice flashing ?
#125 Post by SamuriHL » Mon Apr 29, 2019 8:42 pm
You should be good. We've seen that happen a few times for whatever reason. Almost always the first flash that didn't seem to complete actually did but running it a second time was fine. Sounds like you're good to go.
PeterMac
#126 Post by PeterMac » Mon Apr 29, 2019 9:41 pm
SamuriHL - thank you!, drive work fine, I already record BD-RE DL fine, I also rip regular BD movie with MakeMKV everything seems work, tommorow I will receive my first UHD BD movie Planet Earth II and I will try to rip it on HDD, can't wait :)
#127 Post by SamuriHL » Mon Apr 29, 2019 9:43 pm
Excellent. I suspect you'll be happy with the UHD ripping.
minos1067
#128 Post by minos1067 » Mon Apr 29, 2019 10:23 pm
PeterMac wrote: Mon Apr 29, 2019 9:41 pm SamuriHL - thank you!, drive work fine, I already record BD-RE DL fine, I also rip regular BD movie with MakeMKV everything seems work, tommorow I will receive my first UHD BD movie Planet Earth II and I will try to rip it on HDD, can't wait :)
Bought and ripped both Planet Earth II 4K UHD and Blue Planet II 4K UHD without a problem with the 3.02 UE firmware.
minos1067
#129 Post by minos1067 » Mon Apr 29, 2019 10:27 pm
Please correct, I meant "DE 3.02".
I bought and ripped both Planet Earth II 4K UHD and Blue Planet II 4K UHD without any problem using DE 3.02 firmware.
jonghotti
#130 Post by jonghotti » Tue Apr 30, 2019 2:07 am
How's the updating failure #3 bug fix coming along?
#131 Post by MartyMcNuts » Tue Apr 30, 2019 3:54 am
jonghotti wrote: Tue Apr 30, 2019 2:07 am How's the updating failure #3 bug fix coming along?
There is no fix. This is an enclosure issue, where it is not passing all the required commands through to the drive.
jonghotti
#132 Post by jonghotti » Thu May 02, 2019 2:00 am
MartyMcNuts wrote: Tue Apr 30, 2019 3:54 am
Here's one, what error would come back if you were attempting to flash firmware 1.00 to a drive that already contained 1.00?
#133 Post by MartyMcNuts » Thu May 02, 2019 2:27 am
jonghotti wrote: Thu May 02, 2019 2:00 am
Why would you want to do that?
PeterMac
#134 Post by PeterMac » Thu May 02, 2019 2:37 pm
I ripped Planet Earth II without any problems :D, thank you MartyMcNuts for your flasher.
But what I noticed, I left disc in drive for longer time, and after that drive give weird sounds from it. Is it normal ? is it this sleep bug behavior ?
Edit
OK I read that's this cause by this sleep bug
Does this not damage drive ?
Does this also happen on orginal drive which came with 3.01, 3,02 firmware ? Same happen ?
Does it is Asus bug ?
Does this happen on all kind of discs ?
#135 Post by MartyMcNuts » Fri May 03, 2019 12:26 am
PeterMac wrote: Thu May 02, 2019 2:37 pm I ripped Planet Earth II without any problems :D, thank you MartyMcNuts for your flasher.
Edit
The sleep bug is basically common to all UHD "Friendly" drives. It does not occur on "Official" UHD drives.
