baker12
Post
by baker12 » Wed Apr 24, 2019 12:40 am
So I have an older LG WH12LS30 Blu-ray Drive that I got from a friend a long time ago, and have been using it to rip my BD movies with MKV for awhile now. I just recently heard about LibreDrive, however this is what I see on my drive info:
Product: BD-RE WH12LS30
Revision: 1.02
Serial number: K9JACNE0729
Firmware date: 2013-11-06 12:34:56
Highest AACS version: 66
Disc Information
Label: STAR_TREK_S2D3
Timestamp: 2010-01-05 15:27:41
Data capacity: 43.89 Gb
Since I don't see anything mentioning LibreDrive does that mean mine doesn't support it? Or am I missing something? I even upgraded from FW ver 1.00 to 1.02 this evening to see if that would help.
Post
by Woodstock » Wed Apr 24, 2019 11:51 am
Your drive was built in 2013 - it won't have UHD capability (nothing older than mid-2015 can do UHD) and its chip set was not recognized as being compatible with LD.
baker12
Post
by baker12 » Wed Apr 24, 2019 11:40 pm
Cool. That's what I thought, but wanted to make sure.
Post
by mike admin » Sun Apr 28, 2019 11:28 am
baker12 wrote: ↑Wed Apr 24, 2019 12:40 am
That means that MakeMKV knows nothing about this drive - which is strange. Please make sure that you have a setting "allow contacting web server for updates" enabled. If you still see no LibreDrive info, please send me all files named dump_SD_xxxxx.tgz from MakeMKV data directory (if any) to
support@makemkv.com. Thanks!
conrailguy
Post
by conrailguy » Sun Apr 28, 2019 1:15 pm
mike admin wrote: ↑Sun Apr 28, 2019 11:28 am
Please excuse me in advance for horning in on this thread,but I found a similar drive.I was wondering if this is or could be a"friendly" drive?
Product: BD-RE WH12LS39
Revision: 1.03
Serial number: K9HB8FA5409
Bus encryption flags: 1F
Highest AACS version: 60
Disc Information
Label: TOMBSTONE_USA
Timestamp: 2010-02-12 16:58:16
Data capacity: 37.88 Gb
Disc type: BD-ROM
Number of layers: 2
st4evr
Post
by st4evr » Sun Apr 28, 2019 5:56 pm
conrailguy wrote: ↑Sun Apr 28, 2019 1:15 pm
Revision: 1.03
Disc Information
Disc type: BD-ROM
Number of layers: 2
No, that drive is too old for “UHD friendliness”. It will NOT have the internal hardware required for reading UHD BDs.
Libredrive compatibility and UHD Friendliness can be separate. One does not require the other as they have separate functions.
This thread can be of some help as well:
https://www.makemkv.com/forum/viewtopic ... 16&t=19145
Post
by mike admin » Sun Apr 28, 2019 6:29 pm
This drive won't read UHD, but this drive can be made LibreDrive-compatible. This has some benefits for regular blu-ray as well. Please do send all dump_SD_xxxx.tgz files from MakeMKV data directory to
support@makemkv.com .
conrailguy
Post
by conrailguy » Sun Apr 28, 2019 7:15 pm
Thank you st4ever and Mike for your rapid reply and time,I appreciate it.Now I know what I have got here now!Mike,I just sent the dump you requested.
Thanks again
hilde
Post
by hilde » Tue Mar 31, 2020 3:42 pm
I also own a WH12LS39 and now read on this thread that it could be made LibreDrive-compatible but couldn't find more info about how to do it on the forum.
Dont need UHD capability yet, so the drive would still be ok for me as long as I could get LibreDrive on it.
Could you point in the right direction?
OS device name: E:
Revision: 1.00
Serial number: K93A3MK0011
Firmware date: 2011-11-08 12:34:56
Highest AACS version: 16
Disc Information
Label: RED_BALLOON
Timestamp: 2009-12-02 11:22:23
Data capacity: 19.6 Gb
Disc type: BD-ROM
Number of layers: 1
Post
by Woodstock » Tue Mar 31, 2020 6:28 pm
Drive too old. It will never be UHD-capable. And probably not LibreDrive capable.
Note that UHD capability is not a prerequisite for LD to be of benefit, but the older the drive, the less likely there will be LD-capable firmware available.
hilde
Post
by hilde » Tue Mar 31, 2020 7:41 pm
Hmm, I searched the LG support pages - there is a firmware update to 1.03 available, which might make the drive similar to conrailguy's drive above in terms of firmware version and age.
Revision: 1.03
I will do the update and post the result when it's done.
UHD support isn't that important to me yet, I don't have a single UHD, although that might change
Post
by Billycar11 » Tue Mar 31, 2020 8:04 pm
hilde wrote: ↑Tue Mar 31, 2020 7:41 pm
Revision: 1.03
I would just leave it
hilde
Post
by hilde » Tue Mar 31, 2020 8:22 pm
DId the upgrade to firmware 1.03 but no luck with LD support:
OS device name: \Device\CdRom4
Revision: 1.03
Disc Information
Label: RED_BALLOON
Disc type: BD-ROM
Number of layers: 1
Post
by mike admin » Tue Mar 31, 2020 8:25 pm
hilde wrote: ↑Tue Mar 31, 2020 8:22 pm
Revision: 1.03
This is an ancient drive. But still, LD support for these will be enabled soon (obviously for blu-ray only).
hilde
Post
by hilde » Tue Mar 31, 2020 8:32 pm
Thank you for the info, that's really good news!
I like ancient things
I will stick to the drive and wait for LD support
