Blue Screen of death
farside847
#1 Post by farside847 » Thu Sep 02, 2010 1:16 am
This is my first attempt at using this program, downloaded it today and installed it on my WinXPpro system. Started the program, and popped in my copy of Fifth Element BluRay into my external USB BluRay drive (Asus SBC-06D1S-U). The program started to scan the disk, and then the whole system blue screened. I rebooted and tried it again with the same result. Any ideas?
setarip_old
Re: Blue Screen of death
#2 Post by setarip_old » Thu Sep 02, 2010 3:11 am
Hi!
1) If I remember correctly, under XP, you must be logged on as "Administrator"
2) Try another BluRay disc and see if you get different/better resukts
farside847
#3 Post by farside847 » Thu Sep 02, 2010 4:32 pm
Do I need to be logged in as "Administrator", or does my login just need admin rights? I am not logged in as administrator, but I do have admin rights.
setarip_old
#4 Post by setarip_old » Thu Sep 02, 2010 6:20 pm
The following is a quote of what appears on the "Download" page here:
Computer administrator privileges are required on Windows to run the beta version. This is limitation of Windows SCSI application programming interface. Eventually MakeMKV will not require administrator privileges to run.
farside847
#5 Post by farside847 » Thu Sep 02, 2010 6:22 pm
setarip_old wrote:The following is a quote of what appears on the "Download" page here:
Ok, then that cant be my problem, as I have administrator privileges.
farside847
#6 Post by farside847 » Wed Sep 08, 2010 11:02 pm
I have also now tried this with 3 Bluray discs. They all rip fine with DVDfab on the same system. Does your program just not support XP?
setarip_old
#7 Post by setarip_old » Wed Sep 08, 2010 11:35 pm
I'm sure MakeMKV DOES function under XP.
"mike_admin" will likely provide further insight shortly.
Have you tried signing on as "Administrator", rather than just establishing administrator privileges?
#8 Post by mike admin » Fri Sep 10, 2010 6:11 am
MakeMKV works on XP. I'd say you have a defective enclosure or burner.
setarip_old
#9 Post by setarip_old » Fri Sep 10, 2010 7:37 am
@mike admin
Hi!
That would seem to indicate that there's no hardware problem (enclosure or burner), wouldn't it?
farside847
#10 Post by farside847 » Sat Sep 11, 2010 5:29 pm
Thanks for the replies, sent in a memory dump of the bluescreen to help mike troubleshoot. Hopefully it is fixable :)
njw76
#11 Post by njw76 » Fri Oct 29, 2010 3:23 pm
farside847 wrote:Thanks for the replies, sent in a memory dump of the bluescreen to help mike troubleshoot. Hopefully it is fixable :)
Has there been any progress or a fix regarding this issue? I am having the exact same symptoms. Thank you.
farside847
#12 Post by farside847 » Fri Oct 29, 2010 4:22 pm
nope, I never got it to work. I ended up using DVDfab until this is sorted.
