The Butterfly Effect - Which File Name is Correct?
mike_mgoblue
#1 Post by mike_mgoblue » Sun Apr 21, 2019 8:22 am
I wanted to use MakeMKV on my copy of the blu-ray called The Butterfly Effect. ... But, there was a problem.
There are four different versions of the Director's Cut version of The Butterfly Effect.
There is only one version of the Theatrical Cut version of The Butterfly Effect.
Does anyone know which one is the four Director's Cut versions of The Butterfly Effect is the correct version?
The four different versions of the Director's Cut look like this:
Name: THE BUTTERFLY EFFECT
Source file name: 00200.mpls
Duration: 1:59:38
Chapters count: 21
Segment count: 1
Segment map: 60
File name: THE BUTTERFLY EFFECT_t01.mkv
This version that is Source file name 00200.mpls has two audio tracks - both in "Stereo," but nothing else. The Subtitles of Source File Name 00205.mpls are also only in German. The three Director's Cut versions below each contain two DTS-MA 6.1 audio tracks and two DTS 5.1 surround audio tracks, but do not contain any "Stereo" audio tracks.
Source file name: 00305.mpls
Duration: 1:59:38
Chapters count: 21
Segment count: 1
Segment map: 60
File name: THE BUTTERFLY EFFECT_t02.mkv
Source file name: 00205.mpls
Duration: 1:59:38
Chapters count: 21
Segment count: 1
Segment map: 60
File name: THE BUTTERFLY EFFECT_t03.mkv
Source file name: 00099.mpls
Duration: 1:59:38
Chapters count: 21
Segment count: 1
Segment map: 60
File name: THE BUTTERFLY EFFECT_t04.mkv
The Theatrical Cut version looks like this:
Source file name: 00100.mpls
Duration: 1:53:45
Chapters count: 21
Segment count: 1
Segment map: 61
File name: THE BUTTERFLY EFFECT_t05.mkv
hvnphoto
Re: The Butterfly Effect - Which File Name is Correct?
#2 Post by hvnphoto » Sun Apr 21, 2019 2:35 pm
The segment map is 60 for the Director's Cut, meaning the film is the same for all three selections. It is up to you to choose which languages, audio, subtitles etc. you prefer.
