makemkvcon direct device specification
cdslow
#1 Post by cdslow » Sat Aug 28, 2010 1:26 pm
Is there a way to select CD drive for makemkvcon by device file instead of number?
makemkvcon info disc:/dev/hdc does not work.
If it's impossible now, will you add this function to future program versions?
Re: makemkvcon direct device specification
#2 Post by mike admin » Mon Aug 30, 2010 4:10 am
cdslow wrote:Is there a way to select CD drive for makemkvcon by device file instead of number?
It's not possible now and unlikely to be changed. You can always use --list command to see drive number.
cdslow
#3 Post by cdslow » Mon Aug 30, 2010 11:41 am
mike admin wrote:You can always use --list command to see drive number.
Thanks for your answer. Can you provide exact example of command line to get drive list?
#4 Post by mike admin » Wed Sep 01, 2010 8:39 am
http://www.makemkv.com/developers/usage.txt
makemkvcon -r --cache=1 info disc:9999
