Bad Boys
charlie62
Bad Boys
Post by charlie62 »
Having real problems with the UK version of Bad Boys I'm getting read errors it appears from all over the disc. Anyway at the moment I am trying to rip the whole disc on to the HD and then try and rip that with Makemkv .
My question is how do I transfer the file(assuming it rips the files cleanly)to makemkv to be converted to an mkv. Thanks
charlie62
Re: Bad Boys
Post by charlie62 »
Nothing that can be done,disc files are definitely damaged,same result in four different drives
charlie62
Re: Bad Boys
Post by charlie62 »
Changed disc and the second one worked a treat.
