makemkv streaming blu-ray chews up CPU (it's back)
BitJam2
#1 Post by BitJam2 » Wed Sep 01, 2010 7:39 am
I'm using makemkv-1.5.8 on 64-bit Gentoo GNU/Linux. When I enable streaming, even before any program reads a stream, the CPU usage jumps to 90% on one of more cores. Granted, this is at the lowest clock setting, but it seems like a waste since it is using up all that CPU basically doing nothing. This happens with both makemkv and makemkvcon. The CPU usage is low when it is scanning/reading the disk. It only jumps up when the http server starts up.
I don't think it always did this. I remember streaming and watching blu-ray with only about 30% CPU usage total and makemkv only contributed a fraction of the total, most of it was used by the video client program. Now, htop tells me that makemkv is chewing up CPU even when it is just idling. I can provide a list of recently updated packages but none of them seem to be related to what makemkv does. They are almost all video output programs and libraries.
Makemkv is a fabulous program IMO. If I end up watching Blu-rays regularly, I will buy a copy in order to support your development work. Thank you for making it so easy to watch Blu-rays on Linux.
Re: makemkv streaming blu-ray chews up CPU
#2 Post by mike admin » Wed Sep 01, 2010 8:41 am
Please confirm, the cpu is high when you don't access http server? That seems wrong.
BitJam2
#3 Post by BitJam2 » Wed Sep 01, 2010 9:31 am
Exactly. On both counts. The cpu is high even when I don't access http server. And this seems wrong.
I just tried it again on a different Blu-ray disc. As soon as makemkvcon says "Streaming server started" the CPU usage of one core jumps to 90% and stays that high until I kill makemkvcon.
To confirm nothing is connected to the makemkv http server here is the output of "sudo netstat -autp | grep mkv":
tcp        0      0 *:51000                 *:*                     LISTEN      18145/makemkvcon
udp        0      0 localhost:54163         *:*                                 18145/makemkvcon
udp        0      0 *:56345                 *:*                                 18145/makemkvcon
udp        0      0 *:1900                  *:*                                 18145/makemkvcon
When a client does connect, a line like this gets added to the output:
tcp        0      0 localhost:51000         localhost:44282         ESTABLISHED 18145/makemkvcon
BitJam2
#4 Post by BitJam2 » Wed Sep 01, 2010 11:24 am
The high CPU usage is gone for now. Makemkv in streaming mode with no connections is now only using abut 17% of one core.
I've got no idea why it started using up more CPU and I have no idea why it stopped. I use both Conky and Gkrellm to monitor CPU usage and other resources so I keep a close eye on how much CPU is being used. One clue is that almost all of the makemkv CPU usage is being used by the system not the user. This is true both during the high usage and the normal usage (17% of one core with no connection).
If I see the high CPU usage again I will post again in this thread.
BitJam2
Re: makemkv streaming blu-ray chews up CPU (gone for now)
#5 Post by BitJam2 » Wed Sep 01, 2010 5:23 pm
Today the makemkv CPU usage in (unconnected) streaming mode is less than 2%.
#6 Post by mike admin » Fri Sep 03, 2010 7:17 am
Could it be that you've launched it from root this time?
BitJam2
#7 Post by BitJam2 » Fri Sep 03, 2010 9:47 am
Good question but no, I've always launched it as a normal user. I've probably started steaming about 10 times today. Once the CPU usage went down to 1% or so, it never went back up.
The strange thing ISTM is that the high CPU usage tapered off before going back to close to zero. I had been mucking about installing and upgrading video libraries and players. I was also mucking about with the Nvidia kernel module (trying to get rid of "tearing" *sigh*). It seems possible, perhaps likely, that some of this mucking about contributed to the problem. If so, then I probably won't see it again, or perhaps only see it rarely.
My feeling is that if it happens frequently enough to be annoying then we can probably figure out how to reproduce it and then fix it. Until it then, I'm going to just ignore that it happened.
BitJam2
#8 Post by BitJam2 » Fri Dec 03, 2010 6:14 am
The high CPU usage is back again. It happened yesterday and today watching "The Fellowship of the Ring". Here is the output from "top":
top - 23:05:25 up  5:17,  6 users,  load average: 0.68, 0.34, 0.24
Tasks: 123 total,   1 running, 120 sleeping,   0 stopped,   2 zombie
Cpu(s): 18.0%us,  3.6%sy,  0.5%ni, 76.3%id,  0.5%wa,  0.2%hi,  0.9%si,  0.0%st
Mem:   4061536k total,  1472716k used,  2588820k free,    22536k buffers
Swap:  8008364k total,        0k used,  8008364k free,   373352k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
 2594 jbowlin   20   0  635m 527m 6624 S   67 13.3   1:10.65 makemkvcon
 2639 jbowlin   20   0  693m 164m  51m S   34  4.1   0:38.31 xbmc.bin
 6479 root      20   0  143m  55m  17m S   17  1.4  29:24.25 X
 3010 jbowlin   20   0 19088 1204  868 R    2  0.0   0:00.01 top
 7189 jbowlin   20   0  253m  24m  16m S    2  0.6   1:37.41 gkrellm
    1 root      20   0  3888  656  552 S    0  0.0   0:00.52 init
It is not disastrous, just annoying. When I stop streaming the usage goes down to near zero. It looks like it is mostly time spent in the kernel, not userland.
