Patriot 4K wont rip
murray24
Patriot 4K wont rip
Post by murray24 »
My new LG BH16NS55 with UHD Friendly firmware drive has been working perfectly for 4K rips with makemkv but today no luck.
Ive tried and tried to rip the 4K disc I just bought of The Patriot with no luck over and over, it just won’t load. I have cleaned the disc over and over and still no luck, what does one do now? Do you know if there are any issues with this Universal title?
I have also tried DVDfab with same results.
This is the message I get on makemkv.
MakeMKV v1.14.3 win(x64-release) started
Using LibreDrive mode (v05 id=067EFCA8EA7E)
Saved AACS dump file as C:\Users\Murray/.MakeMKV/MKB21_v61_Patriot,_The_(2000)_6721.tgz
OS device name: E:
Product: BD-RE BH16NS55
Revision: 1.02
Serial number: KLKIBTD5243
Firmware date: 2115-12-11 14:40
Highest AACS version: 66
Firmware version: 1.02
Disc Information
Label: THE_PATRIOT_2000
Timestamp: 2018-03-16 13:46:46
Data capacity: 91.43 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Re: Patriot 4K wont rip
murray24
Post by murray24 »
sorry I dont understand your reply???
Post by SamuriHL »
That title is one of 2 aacs 2.1 titles and isn't supported.
Sent from my Pixel XL using Tapatalk
st4evr
Post by st4evr »
It’s discussed in more detail here:
https://www.makemkv.com/forum/viewtopic ... 12&t=17489
And here:
https://www.makemkv.com/forum/viewtopic ... iot#p72655
And forum search function does work:
https://www.makemkv.com/forum/search.ph ... ds=Patriot
Showing where it has already been discussed multiple times over.
Chasetheace
Post by Chasetheace »
Fury and The Patriot will rip with DeUHD.
But program interface is lifeless like dead dog.
I am sure More will sort soon as he has been producing some amazing software.
smartieyoung
Post by smartieyoung »
I had a 6 month subscription to de uhd and it worked as advertised.i dont know when and if make mkv will support these titles.what i just found out tonight was if i took the iso file disc that deuhd created and i put that decrypted disc in my uhd friendly drive and start makemkv it will copy the file to my computer as a regular backup.i have yet to sit down and watch the backup yet but i learned a little something tonight
st4evr
Post by st4evr »
smartieyoung wrote: Thu May 23, 2019 4:33 am I had a 6 month subscription to de uhd and it worked as advertised.i dont know when and if make mkv will support these titles.what i just found out tonight was if i took the iso file disc that deuhd created and i put that decrypted disc in my uhd friendly drive and start makemkv it will copy the file to my computer as a regular backup.i have yet to sit down and watch the backup yet but i learned a little something tonight
Discussed this exact same thing in this thread:
https://www.makemkv.com/forum/viewtopic ... iot#p71346
Which you created 5 months ago. So..... you re-discovered/re-learned the exact same thing 5 months later?
smartieyoung
I guess i learned i could do it directly from the iso disc deuhd created.the last time i used it before my subscription expired.the way of doing the backup with makemkv is not new,i just had a full iso 100 gb disc from where i sourced this file from.sorry to confuse or double post,str4ever.i will be more careful in future.
