1.14.3 makemkvcon "too old"
navier
Post by navier »
After updating to 1.14.3 makemkvcon won't work with the Error message:
This application version is too old.  Please download the latest version at http://www.makemkv.com/ or enter a registration key to continue using the current version.
Any workarounds for this please?
T'hain Esh Kelch
Re: 1.14.3 makemkvcon "too old"
Post by T'hain Esh Kelch »
Use a working registration key?
navier
Post by navier »
The GUI is working with the latest Key but the command line is not
TheDocta
Post by TheDocta »
I'm having the same issue on a Macbook Pro running Mojave. Where do I find the registration code it's asking for?
Same place it always is, if you're not using your own permanent key: viewtopic.php?f=5&t=1053
ch3typs1
Post by ch3typs1 »
Thanks for your help. I was having the same issue.
TheDocta
Post by TheDocta »
Thank you!
EmilyJames
Post by EmilyJames »
thank you!!!
