Cast Away failed to rip
OrvilleP
Post by OrvilleP » Tue Aug 31, 2010 4:45 pm
MakeMKV v1.5.8 win(x64-release) started
Cell 45 was discarded (structure protection?)
Title #0 was added (44 cell(s), 2:23:21)
Title #1 has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 with special attributes was skipped
Title #6 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6/5 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory Y:/DVD MKVs/Cast Away
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, OPERATION IN PROGRESS' occured while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '420767744'
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, OPERATION IN PROGRESS' occured while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '420833280'
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, OPERATION IN PROGRESS' occured while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '421095424'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occured while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '421095424'
Failed to save title 0 to file Y:/DVD MKVs/Cast Away/title00.mkv
0 titles saved, 1 failed
setarip_old
Re: Cast Away failed to rip
Post by setarip_old » Tue Aug 31, 2010 8:17 pm
Hi!
1) Clean the disc (All that time exposed to salt air on that island ;>})
2) Increase the number of retries to 20
OrvilleP
Post by OrvilleP » Sat Sep 04, 2010 1:09 pm
Setarip_old,
I cleaned the Cast Away disc as described before, set MakeMKV retries to 20 and tried to rip again. No luck. The log file follows. I have attaches a zip of the eight IFO files.
Best regards,
Sterling Lindsey
Debug logging enabled, log will be saved as C:\Users\Lindsey/MakeMKV_log.txt
Saving 1 titles into directory R:/DVD MKVs/Cast Away
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, OPERATION IN PROGRESS' occured while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '426698752'
DEBUG: Code 0 at }&i)/,Bl1a7DLNqM:213136769
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, OPERATION IN PROGRESS' occured while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '427616256'
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, OPERATION IN PROGRESS' occured while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '437512192'
DEBUG: Code 100795399 at }1=ipBp?g(KEt3a_1@:121263636
DEBUG: Code 100795399 at }1=ipBp?g(KEt3a_1@:213130007
DEBUG: Code 0 at F,8'XhP~=JiSm$lNbOCO:213130628
DEBUG: Code 0 at rqRKLouR{ SWzIg@'"_:121261704
DEBUG: Code 0 at F,8'XhP~=JiSm$lNbOCO:213130513
DEBUG: Code 213629 at F,8'XhP~=JiSm$lNbOCO:213129639
Failed to save title 0 to file R:/DVD MKVs/Cast Away/title00.mkv
OrvilleP
Post by OrvilleP » Thu Sep 23, 2010 5:49 pm
Setarip_old,
MakeMKV 1.6.0 does not rip DVD Castaway as was the case for version 1.5.8. The log fi8le is attachment 1.
Sterling Lindsey
setarip_old
Post by setarip_old » Thu Sep 23, 2010 6:48 pm
You have either a flawed (or dirty) disc or a failing drive...
