This one unfortunately won't work.PRAGMA wrote: ↑Wed Apr 10, 2019 1:31 pmGuys can yall just update me, will this work:
https://www.amazon.co.uk/gp/product/B00Z1LXAJG
And if it does work, is it more or less just plug and play using MakeMKV?
UHD drives
Re: UHD drives
Re: UHD drives
Remember it's always a good idea, in my opinion, to have an LG and and ASUS around for some of the more pesky discs that won't rip in one but will in the other.
Re: UHD drives
No, this drive won't work. I believe it actually contains a pioneer drive inside. Thus, not compatible.PRAGMA wrote: ↑Wed Apr 10, 2019 1:31 pmGuys can yall just update me, will this work:
Re: UHD drives
LG WH16NS60 -
https://www.amazon.com/LG-Electronics-B ... B079LR2Q67
LG WH16NS40 -
https://www.amazon.com/LG-WH16NS40-Inte ... B00E7B08MS
LG BH16NS40 -
https://www.amazon.com/LG-Electronics-B ... B00HQP9FIA
I think I've narrowed down what I want to these 3 drives. and I want to house them in this:
https://www.amazon.com/OWC-Mercury-Opti ... B06XRCCV44
Can someone tell me which one is better to get? Thanks.
LG WH16NS40 -
LG BH16NS40 -
Re: UHD drives
While better and best are subjective to some degree the WH16NS60 has more going for it than the other two and now that it's supported by makemkv it's even a better choice, in my opinion.
Re: UHD drives
Yes, definitely get the WH16NS60; it has the added joy of the UltraHD Blu-ray official logo!andyv_it wrote: ↑Tue Apr 16, 2019 2:42 pmLG WH16NS60 -
Re: UHD drives
I just got my new LG WH16NS60 and USB 3.0 external case in the mail today. I’m quite eager to start ripping 4K movies with it. I’m a bit new to the scene and not entirely sure what is the best firmware type/revision to put on it. My unit came with 1.01 stock on it. If someone could point me in the direction of the proper flasher and a tutorial on how to use it it properly it would be highly appreciated!!!
Re: UHD drives
You’ll want the 1.00 firmware and the flashers and that is part of this
https://www.makemkv.com/forum/viewtopic ... 19&t=19113
Re: UHD drives
It appears the FW in that file is 1.01.....not 1.00. Is that the one that should be used to allow the drive to rip 4k disks?jonghotti wrote: ↑Mon May 13, 2019 9:03 pmYou’ll want the 1.00 firmware and the flashers and that is part of this
Re: UHD drives
Ah yes, I noticed that after I posted this, my bad. It appears I copied the needed files into this directly when I saved it locally. I can email you the file I use no sweat but won't post it here since there may be a de or mk around that fixes this. Feel free to ping me at alexcoluzzi32@gmail.comwingnut144 wrote: ↑Wed May 15, 2019 4:16 pmIt appears the FW in that file is 1.01.....not 1.00. Is that the one that should be used to allow the drive to rip 4k disks?jonghotti wrote: ↑Mon May 13, 2019 9:03 pmYou’ll want the 1.00 firmware and the flashers and that is part of this
https://www.makemkv.com/forum/viewtopic ... 19&t=19113![]()
Re: UHD drives
is it safe to buy a UHD friendly listed drive new like here
https://www.amazon.de/dp/B00DRHOL44
or did the makers update them so you cant get new Friendly drives anymore?
after all the opening post was written in 2017.
Re: UHD drives
No. You are late to the game to be able to simply get one from Amazon ready to go. Drive manufacturers/vendors caught on months ago.My1xT wrote: ↑Sat May 18, 2019 7:54 pmis it safe to buy a UHD friendly listed drive new like here
Reading some of the posts right above yours should have alluded to this fact. Jumping to the last page to post and not doing any reading will not help you and just get you into trouble.
Start by reading this:
https://www.makemkv.com/forum/viewtopic ... 16&t=18873
As it contains very helpful information in the first few posts including a “how-to” video created by a member of this forum.
The forum search function also works:
https://www.makemkv.com/forum/search.ph ... =BW-16D1HT
So inform yourself as much as possible to make an educated decision.
Re: UHD drives
Like 18 or so, on the day after that initial "key drop" in December 2017 right?
Re: UHD drives
I've just received this drive but I'm not sure if it can be flashed to 1.00 or 1.03 for UHD support
The sticker label states that it's a UHD Blu-Ray / DVD Writer that was manufactured in Oct 2016.
Also, to flash a drive, I'll need a real SATA connection not via a USB adapter?
OS device name: E:
Manufacturer: hp HLDS
Product: BDRE BU40N
Revision: BW41
Serial number: 642CNxxxxxx
Firmware date: 2116-08-16 15:28
Bus encryption flags: 1F
Highest AACS version: 31
Re: UHD drives
I take it, you have already tried a UHD disc with that firmware?pegasus21 wrote: ↑Wed May 22, 2019 1:14 pmI've just received this drive but I'm not sure if it can be flashed to 1.00 or 1.03 for UHD support
The sticker label states that it's a UHD Blu-Ray / DVD Writer that was manufactured in Oct 2016.Code: Select all
Drive Information OS device name: E: Current profile: BD-ROM Manufacturer: hp HLDS Product: BDRE BU40N Revision: BW41 Serial number: 642CNxxxxxx Firmware date: 2116-08-16 15:28 Bus encryption flags: 1F Highest AACS version: 31
I'm pretty sure I have read somewhere that firmware BW50 works. Maybe that was for a BU50N drive. I can't remember.
Anyway, you can use a SATA / USB adapter (you will also need a SATA / slimline ATA adapter) to flash the drive, but you might be better off using SATA and the old Dosflash method to extract that firmware first.
What I would do:
1. Use SATA connection and old Dosflash method to extract firmware BW41 from your drive.
2. Reboot.
3. Use the modified or patched windows flasher to flash the drive using a SATA / USB adapter to 1.00 and see if it works.
Then, if the drive doesn't work with 1.00, then you can use the old Dosflash method to restore your BW41 firmware.
