Problem converting BD
Jonas
#1 Post by Jonas » Sat May 02, 2009 1:34 pm
Hello
I have problems converting a BD structure on my HD to MKV. I press the "Open files" button and navigate to the BDMV folder and opening index.bdmv or MovieObject.bdmv gives the following message...
Opening files on harddrive at D:/bd.quantumofsolace-Hellboy/
AACS directory not present, assuming unencrypted disc
FAILURE: Code 7 at ;'Pc{4=SRqu?>MiW%`&i:213132790
FAILURE: Code 0 at Yo8sMGw8~}Uf>pF-B'h?U:29395839
FAILURE: Code 0 at Yo8sMGw8~}Uf>pF-B'h?U:121263613
FAILURE: Code 0 at AY$B%2*jyhSl4,h!l-^:29393746
FAILURE: Code 0 at ?bQyollg{nTj.&e:~:213132399
Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
FAILURE: Code 0 at @3[<f)M;U@W7s6ps:213134354
Title #00000.mpls was skipped
Any idea what might be the problem? MakeMKV v1.4.2 is the version being used.
Brgds... /Jonas
Re: Problem converting BD
#2 Post by mike admin » Sun May 03, 2009 3:28 pm
It says that your blu-ray disc contains non-conformant mpeg4 video stream. What kind of input is that? It it decrypted blu-ray or custom-made avchd disc?
Jonas
#3 Post by Jonas » Sun May 03, 2009 4:59 pm
Hmm... wish I knew. It's something I downloaded and it looks like a Blu-Ray structure. My Popcorn Hour can play it but since it couldn't display the subtitles I wanted to convert it to MKV instead... that's how I found your program. If you have Usenet you could always search for and download bd.quantumofsolace-Hellboy and see for yourself ;-)
Anyway... thanks for a fine program (even if it didn't help me this time) :)
#4 Post by mike admin » Tue May 05, 2009 2:47 pm
Thank you for clarification. Apparently this is a incorrectly created BD rip - it uses mpeg4 video stream that does not conform to blu-ray specification. It is unlikely that MakeMKV will ever support this. Most players will probably play it fine though.
Jonas
#5 Post by Jonas » Wed May 06, 2009 9:38 am
Thank you for the explanation. Now at least I know why it didn't work.
Brgds... /Jonas
