Linux Not Detecting LibreDrive Functionality
spicyboots
#1 Post by spicyboots » Sun Mar 31, 2019 7:02 pm
So I downloaded the 3.02 firmware for my ASUS BW-16D1HT and flashed that, and afterward was able to do a test rip on the windows machine I was using without any issue. Afterwards I installed it in my Linux machine (Mint 19.1) and when I go to try and rip a disk I get:
MakeMKV v1.14.3 linux(x64-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Saved AACS dump file as /home/<user>/.MakeMKV/MKB20_v61_THE_CABIN_IN_THE_WOODS_2565.tgz
I have already tried uninstalling and reinstalling MakeMKV but that did not seem to help. Any advice would be appreciated!
spicyboots
[SOLVED] Re: Linux Not Detecting LibreDrive Functionality
#2 Post by spicyboots » Sat Apr 06, 2019 4:59 pm
Hey so if anyone else is having this issue, here is how I fixed it...
Backup the config files (important if you have a registration key)
mv ~/.MakeMKV ~/.MakeMKV_bkp
Remove the actual program
sudo rm /usr/bin/makemkv
sudo rm /usr/bin/makemkvcon
Rebuild from source (the software manager did not work for some reason)
wget http://www.makemkv.com/download/makemkv-bin-1.14.3.tar.gz
wget http://www.makemkv.com/download/makemkv-oss-1.14.3.tar.gz
tar xvzf makemkv-oss-1.14.3.tar.gz
tar xvzf makemkv-bin-1.14.3.tar.gz
cd makemkv-oss-1.14.3
./configure
make
sudo make install
cd ../makemkv-bin-1.14.3
make
sudo make install
Then you just need to copy over your registration key, start MakeMKV and you should be good to go! Now when you insert a disk into your libredrive capable drive, it should download the additional packages.
Cheers!
icntoaun
#3 Post by icntoaun » Thu Apr 30, 2020 4:04 am
Thank you so much! I was having a very similar issue with the makemkv snap - building from source fixed this and several other problems I was having.
ameliascud
#4 Post by ameliascud » Thu Mar 07, 2024 5:05 pm
Thank you for this post. This was exactly my problem. After hours of searching, I finally was able to articulate the right question. Why is MakeMKV not utlizing libredrive on my linux mint computer?!?
This was exactly what I was looking for. Many thanks for posting!
-- Scud
