I doubt the MTL settings match across users. Default is 120 seconds; I have mine set at 30, and I've seen people encourage larger settings as a way to fight obfuscation (reduce the number of titles to look through).
The important thing is the :Source file name:" shown in the info window.
Robin Hood (2018) playlist obfuscation
Re: Robin Hood (2018) playlist obfuscation
I am also having an issue finding the correct Playlist on a Canadian Steel book edition from Best Buy. I cannot find any of the listed source files, and all my segment maps start with 513. Are there any other Canadians with the correct playlist?
How in the world were you able to figure out that this is the correct playlist with over 100 to choose from? I trust you but tell me you had a slick method of testing besides going through each one, right?Vanorie wrote: ↑Tue Feb 19, 2019 11:34 amI did not have the above file. This is the one that worked for me.
Title information
Source file name: 00855.mpls
Duration: 1:56:08
Chapters count: 16
Segment count: 15
Segment map: 502,512,501,506,514,515,505,510,504,511,508,503,513,509,507
File name: Robin Hood_t299.mkv
Yes Retail (U.S.A) - Red Box - Netflix - Amazon - Retail (U.K) which seem to be the most Used MPLS type not just this one worked for me to stop confusion
- Contact:
https://www.makemkv.com/forum/viewtopic.php?f=6&t=16251RxGator wrote: ↑Tue Feb 26, 2019 5:13 amHow in the world were you able to figure out that this is the correct playlist with over 100 to choose from? I trust you but tell me you had a slick method of testing besides going through each one, right?Vanorie wrote: ↑Tue Feb 19, 2019 11:34 amI did not have the above file. This is the one that worked for me.
Title information
Duration: 1:56:08
Chapters count: 16
Segment count: 15
I have a Canadian pressing of the disc, and the correct playlist for this one turns out to be:
Source file name: 00289.mpls
Segment map: 513,505,509,515,512,514,508,510,507,501,506,503,504,511,502
File name: Robin Hood_t115.mkv
I have read on John Wick playlist question forum that the playlist that comes with FPL_Mainfeature should be the right playlist.
When I opened RobinHood Redbox Version I got both playlists FPL_Mainfeature(00470.mpls) and also the confirmed one 00855.mpls also
Which way should I go Guys ?
