babypuncher
#1
Post
by babypuncher » Fri Apr 05, 2019 4:38 am
MakeMKV looks like it's reading the disk for about half a second then it just says "No disk inserted". I get this on Blu-Rays and DVDs.
OS device name: F:
Product: BD-RE WH16NS40
Revision: 1.03
Serial number: SIK9GE3C8195
Firmware date: 2117-11-21 16:53
Highest AACS version: 66
Firmware version: 1.03
#2
Post
by MartyMcNuts » Fri Apr 05, 2019 4:46 am
babypuncher wrote: Fri Apr 05, 2019 4:38 am
OS device name: F:
Revision: 1.03
How old is your drive? Does it say SVC: NS50 on the label?
babypuncher
#3
Post
by babypuncher » Fri Apr 05, 2019 5:00 am
Pretty old (I got it in 2015), it does not say SVC: NS50 on the label.
#5
Post
by MartyMcNuts » Fri Apr 05, 2019 5:53 am
babypuncher wrote: Fri Apr 05, 2019 5:00 am
Yep, as Billy said. That drive is too old and is not UHD compatible.
babypuncher
#6
Post
by babypuncher » Fri Apr 05, 2019 8:18 pm
Thanks, fortunately this is just an old drive that I don’t care much for and felt like experimenting with. Does anyone know where I can get the appropriate firmware file for my drive?
#7
Post
by MartyMcNuts » Fri Apr 05, 2019 11:49 pm
babypuncher wrote: Fri Apr 05, 2019 8:18 pm
Here you go.
#8
Post
by SamuriHL » Sat Apr 06, 2019 12:20 am
But again, you can't just flash that firmware with the Windows tools. You will need to dump your existing firmware with dosflash, use the datamover tool to move your encryption and calibration data from that extracted firmware into the firmware that Marty just provided, and then use dosflash to flash the newly created firmware. If you deviate from that process it could permanently brick the drive.
droopie
#9
Post
by droopie » Fri Aug 28, 2020 3:48 am
MartyMcNuts wrote: Fri Apr 05, 2019 11:49 pm
Here you go.
LG_WH16NS40_(NS40)_1.02_Original_Dump.bin.zip
I did the same thing as op, I am literally in bed unable to sleep looking up info when I found this post. My drive turned out to be Aug 2014 rom 1.0 ns40. Hoping the dosflash method restores the drive! Can't wait to wake up tomorrow (hopefully)
