LG BH16NS50 drive
Nizumzen
LG BH16NS50 drive
#1 Post by Nizumzen » Thu Apr 04, 2019 5:18 pm
I've looked in the sticky thread for UHD friendly drives, and I notice that my drive is not listed (LG BH16NS50) but other drives in the same series are. Before I go ahead and spend some money on a 4k Blu-ray is my drive a UHD friendly drive or am I out of luck? I have never upgraded the firmware of the drive. I'd rather not buy a 4k Blu-ray without knowing as they are quite expensive and I don't have a 4k Blu-ray player hooked up to my TV yet.
Re: LG BH16NS50 drive
#2 Post by Woodstock » Thu Apr 04, 2019 6:00 pm
When you start MakeMKV, what does it say about your drive in the Info box?
Nizumzen
#3 Post by Nizumzen » Thu Apr 04, 2019 6:04 pm
Product: BD-RE BH16NS50
Revision: 1.00
Firmware date: 2117-03-10 16:34
Highest AACS version: 56
The only thing I haven't posted is the serial number which I'm not sure if that is OK to post on the internet. Hopefully, that'll help.
#4 Post by MartyMcNuts » Fri Apr 05, 2019 4:03 am
Put a UHD disc in and then tell us what MakeMKV says in the info box.
Nizumzen
#5 Post by Nizumzen » Sat Apr 06, 2019 3:01 pm
MartyMcNuts wrote: Fri Apr 05, 2019 4:03 am Put a UHD disc in and then tell us what MakeMKV says in the info box.
I just got my first UHD disc today and it seems to be working!
This is the output from the disc info in MakeMKV:
Disc Information
Label: READY_PLAYER_ONE
Timestamp: 2018-06-04 16:53:21
Data capacity: 83.23 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Am I right in thinking that my drive is UHD compatible and can rip UHD discs? I don't want to start ripping until I am sure so sorry for the stupid questions.
#6 Post by MartyMcNuts » Sat Apr 06, 2019 10:44 pm
Nizumzen wrote: Sat Apr 06, 2019 3:01 pm
Disc Information
Number of layers: 3
Well, it looks that way. Just start ripping. It will either work or it won't. Simple.
Nizumzen
#7 Post by Nizumzen » Sun Apr 07, 2019 6:07 pm
MartyMcNuts wrote: Sat Apr 06, 2019 10:44 pm
Disc Information
Number of layers: 3
It works! Thank you very much for your help. Takes 2 hours to do a complete rip though. This seems to be something that I'll leave overnight to complete.
Edit: After 30 minutes of ripping it is only going to take 1 hour which is much better.
#8 Post by SamuriHL » Sun Apr 07, 2019 6:40 pm
Yea, it's variable speed and the different layers impact the speed. Usually ripping takes about 45 minutes on average.
