Hi.
New to forum. I've been using LG BP50NB40 for a while now with little to no issue on my macbook air. i'm on mkv v. 14.1.
I built a PC recently and hooked up the same drive, installed the latest version of mkv, and had issues out of the gate. mainly with blu ray though oddly enough. I can't locate the errors in a log - but hoping this was a known issue you could help me troubleshoot. If not, i'll recreate them and post the data.
So - thinking it was the newest version causing problems (i noticed something about libre that i hadn't seen on the Mac), i installed the same 14.1 on the PC. This didn't fix the issue. I moved the drive back to the MAC which runs on 14.1, and it's handling the same blu ray disc with no issue at all.
The disc did OK on dvds, so i wasn't sure..
thoughts?
Possible Windows Issue? (drive worked on Mac)
questions00
Re: Possible Windows Issue? (drive worked on Mac)
What is the exact problem/error? You wrote nothing about it.
And please post the Debug log.
Good Luck
questions00
Here's what it says when i don't have a disc in on the right:
OS device name: F:
Product: BD-RE BP50NB40
Revision: 1.01
Serial number: SIM12212A5240
Firmware date: 2117-11-23 16:15:
Highest AACS version: 19
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Invalid! XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Invalid! XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Invalid! XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Invalid! XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX: MT1959
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Invalid! XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX: 1.01
OS device name: F:
Revision: 1.01
No complete Debug Log, no error/problem description, no solution. Don't know what you expect from others with this kind of cryptic informations!
Good Luck
i have seen this before you need to update your makemkv and open a regular bluray that should redownload the latest sdf and hk and it should fix the libre drive info being messed upquestions00 wrote: ↑Thu Apr 04, 2019 8:06 pmHere's what it says when i don't have a disc in on the right:
OS device name: F:
Revision: 1.01
