Beta Key
Re: Beta Key
I plan on purchasing this product when it moves out of beta, but for now is there anything we can do to use the program since the "Beta Key" has expired?
Thanks,
John
Thanks,
John
Re: Beta Key
Yah - about/MakeMKV says it's good until Sept 12th - but when I try to use it - it tells me the evaluation period has expired and I need to purchase a key and refuses to functionmoviebuff wrote:Beta key expired but it isnt even Sept yet?
I intend on purchasing MakeMKV when it's out of beta
- Contact:
Re: Beta Key
Beta key updated. You can purchase product now if you like. http://www.makemkv.com/buy
