Seven Samurai Criterion Disc 2 - Can't read AACS VID from disc
werepancake
Post by werepancake »
I'm trying to rip my Criterion Blu-ray edition of Seven Samurai and am running into some issues. The first disc with the actual film worked just fine, but the second disc with the supplementary features gives me a bunch of ILLEGAL REQUEST errors and leaves me with the error "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive".
Is there anything I can do about this? I'm confused why one disc worked but the other one didn't. I've attached the debug log.
Thanks,
werepancake
MKB_v18_Seven_Samurai_Disc_2_9AB6.tgz
(149.68 KiB) Downloaded 441 times
werepancake
Re: Seven Samurai Criterion Disc 2 - Can't read AACS VID from disc
So I was getting impatient and decided to try ripping the disc again... Now it works?
Unfortunately I'm not really sure what fixed this issue. The only things I did that I can think of are that I 1. Restarted my computer and 2. Installed Java. Don't know if either of those things actually made any difference but if anyone finds this thread with the same issue, maybe it'll help.
