The Fifth Element - Region 4
akm1x00
#1 Post by akm1x00 » Sun Aug 29, 2010 8:06 pm
Fails about 1/3 of the way in.
This log is from an ISO, but, the physical disc fails in the same way, I keep the ISO around and retry it every release.
Debug log started at Sun Aug 29 19:48:36 2010 , written by MakeMKV v1.5.8 win(x64-release)
001005:0000 MakeMKV v1.5.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\akm/MakeMKV_log.txt
003028:0000 Title #0 was added (18 cell(s), 2:01:05)
003025:0000 Title #1 has length of 20 seconds which is less than minimum title length of 181 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory S:/Rips
001003:0020 DEBUG: Code 149 at 2rn9)J;%$tM]gNj!?H\:29397426
FS ID=V_MPEG2 C=149
C_00000=ZeNqNV3k41F37P9
Then there's a lot more code (about 700K worth) ending with
001003:0020 DEBUG: Code 0 at Xx?t\%'u.k;,A)R.CQ8*l:29397449
005003:0000 Failed to save title 0 to file S:/Rips/title00.mkv
005004:0080 0 titles saved, 1 failed
crowfax
Re: The Fifth Element - Region 4
#2 Post by crowfax » Sun Aug 29, 2010 8:15 pm
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
akm1x00
#3 Post by akm1x00 » Mon Aug 30, 2010 9:48 pm
crowfax wrote:Have you done this:
http://www.makemkv.com/faq/item/8/catid/6
Yes, but, I'm happy to do it again if required.
