Japio
Post by Japio » Fri Mar 29, 2019 2:09 pm
MartyMcNuts wrote: Sat Mar 23, 2019 11:24 pm
Japio wrote: Sat Mar 23, 2019 4:05 pm Just tried to update my drives.
On my BW-16D1H-U I immediately get "Updating Failure #1."
On my LG BP60NB10 The drive only opens and immediately get "Updating Failure #3."
1. I'm certain that the BW-16D1H-U actually contains a Pioneer drive, (thus not LibreDrive or UHD friendly) and not downgradeable.
2. I don't think the BP60NB10 can be flashed at this point in time. (Please talk to @jonghotti as I think he has one).
Both BW-16D1H-U and BP60NB10 are in the mk-firmware-pack-20190319. So I guess that says it should be supported.
I Would like to know what Failure #1 and #3 are and how te resolve these.
cnjvh
Post by cnjvh » Fri Mar 29, 2019 4:25 pm
Using the flash tool and FW from post 1, is it still necessary to dump the original FW and merge it? Or can I just flash as-is on a new drive (16D1HT)?
Thx!
Post by SamuriHL » Fri Mar 29, 2019 4:42 pm
You do not need to dump the firmware and merge when using the Windows based flasher in this thread.
Post by MartyMcNuts » Fri Mar 29, 2019 10:53 pm
Japio wrote: Fri Mar 29, 2019 2:09 pm
Japio,
Failure #3 - means the external enclosure is not passing through all required commands to the drive, so unable to flash properly.
Failure #1 - Not 100% about this as only a couple of people have had this error but I'm leaning towards an "incompatible drive".
Cheers.
planet1
modified ASUS Flasher
Post by planet1 » Sat Mar 30, 2019 3:29 pm
Dear MartyMcNuts,
thank you for providing this FW flash tool, I successfully used it to LIBERATE my Buffalo BRXL-PT6U2VB external slim drive.
Re: modified ASUS Flasher
Post by MartyMcNuts » Sun Mar 31, 2019 2:16 am
planet1 wrote: Sat Mar 30, 2019 3:29 pm Dear MartyMcNuts,
You're welcome!
jonghotti
Post by jonghotti » Sun Mar 31, 2019 5:42 am
So the BP60NB10 is currently unusable as a UHD compatible drive, because like a crab and it's shell, the drive lives in it's enclosure :)
jerryfudd81
Post by jerryfudd81 » Sun Mar 31, 2019 8:35 am
I asked previously but is it possible to use 'ASUS_ODD_FW_Changer_(Modified).exe' to go directly to DE 3.01 on the BW-161HT from 3.03?
If so what is the purpose of 'ASUS ODD FW 3.02 Updater for BW-16D1HT (Patched).exe' as I thought that was to downgrade the DE 3.02 to 3.01?
(my 2nd BW-161HT arrives Tuesday so I'll actually get to use some of this info!)
Post by Billycar11 » Sun Mar 31, 2019 9:25 am
jerryfudd81 wrote: Sun Mar 31, 2019 8:35 am Hi,
You can upgrade or downgrade to any firmware you want no need to flash in order or anything like that. Just go directly to the version you want
mathewbeall
Post by mathewbeall » Sun Mar 31, 2019 5:13 pm
MartyMcNuts wrote: Thu Mar 28, 2019 4:34 am
mathewbeall wrote: Thu Mar 28, 2019 2:07 am Quick question - I have the ASUS 161DHT drive, and it came with 3.03 - I got the latest firmware updater - and attached it to a win10 machine via SATA - and I am getting the error occured during getting handle of the device : error 5
Any ideas?
AnyDVD and the device manager see it just fine, and it's not hooked up via USB.
Matt
Weird.. I haven't heard of anyone getting that error when directly connected to SATA port on motherboard, unless they have an old drive. Just to make sure, how old is your drive? If it is newer than October 2015 can you give the LG flasher a try. (Link below..) Just unzip it in the same folder as the ASUS flasher + firmware.
BH14NS40_N1.00-A4_patched.zip
Let us know how you go.
So - this turned out to be a total newb mistake - I wasn't "running as administrator" when I went to fire up MakeMKV. All good now. :)
Post by MartyMcNuts » Sun Mar 31, 2019 11:27 pm
I released that patched ASUS 3.02 flasher (which only downgrades a BW-16D1HT 3.03 to 3.02) a while before I released the modified flasher (can flash any drive with any firmware).
Therefore, there isn't really any need for the original 3.02 patched flasher anymore. If you have downloaded the modified fw changer, you are good to go.
Hope that provides clarification for you.
jerryfudd81
Post by jerryfudd81 » Mon Apr 01, 2019 7:27 am
MartyMcNuts wrote: Sun Mar 31, 2019 11:27 pm
perfect thanks, I'd been searching the forums trying to get upto speed but there's allot of history over a few topics (+ edits) and I'm consuming it all in one go so just wanted to make sure I was understanding it correctly.
really appreciative of all the work that's put in.
sl1pkn07
Post by sl1pkn07 » Tue Apr 02, 2019 6:08 pm
Hi
Thank to you, my new unit asus bw-16d1ht (fw 3.03, manufacture date october 2018) has been downgrade to "DE" fw3.02!
but i have a little (aka stupid) question about the firmware includes into the zip
comes with 2 firmwares for my unit. fw 3.01 and 3.02. why is this if the other compatible units have only one?
greetings
Post by SamuriHL » Tue Apr 02, 2019 6:15 pm
3.01 and 3.02 are both UHD friendly. He included them for completeness, but, quite frankly a few of us have found that MK 3.10 to be the overall best firmware for this drive so far. That being said, 3.02 works very well. I used it on mine for over a year without issue.
