Tiny Toon Adventures S1D4A
darthtye
Post by darthtye »
If I attempt to use the current version 1.14.3 or previous 1.14.2 the import starts but data is never written to the disk. It just sits stating Output Size: 4.0k indefinitely.
Using version 1.9.10 it works fine no problems
darthtye
Re: Tiny Toon Adventures S1D4A
Post by darthtye »
After testing tracked the problem down to having cc scan enabled. I know cc scan was added recently so bug likely in there somewhere. Disabling cc scan allows disk to import properly with standard vob sub files.
Screen Shot 2019-04-02 at 11.37.00 AM.png (17.76 KiB) Viewed 6152 times
