Fantastic beasts the crimes of grindelwald UHD DUMP
pea458
Post by pea458 »
fantastic beasts the crimes of grindelwald fail to decrypt in the latest version of MakeMKV (1.14.2). The dump files for films have been sent to svq@makemkv.com.
pea458
Re: Fantastic beasts the crimes of grindelwald UHD DUMP
Post by pea458 »
it's supported now thank dev. :P :P
brix22
Post by brix22 »
I had no luck with MakeMKV 1.14.3.
"Using LibreDrive mode (v04 id=76A0C3CD522E)
Saved AACS dump file as /Users/jkl/Library/MakeMKV/MKB20_v66_Fantastic_Beasts-_The_Crimes_of_Grindelwald_516F.tgz
Failed to open disc"
Post by d00zah »
brix22 wrote: Tue Mar 12, 2019 9:28 pm Saved AACS dump file as /Users/jkl/Library/MakeMKV/MKB20_v66_Fantastic_Beasts-_The_Crimes_of_Grindelwald_516F.tgz
MakeMKV version is (~) irrelevant.
SOP is to email /Users/jkl/Library/MakeMKV/MKB20_v66_Fantastic_Beasts-_The_Crimes_of_Grindelwald_516F.tgz to svq@makemkv.com & wait for Mike to add the key. You'll know it's available when the disc successfully decrypts.
bmillham
Post by bmillham »
Retail version purchased at Walmart is ripping just fine for me.
Swaps
Post by Swaps »
Not working from best buy. Sent in dump.
brix22
Post by brix22 »
Did send the in the dump immediately after post.
Retail version purchased at Best Buy.
LurkerSteve
Post by LurkerSteve »
I too am unable to dump mine.
riprunn
Post by riprunn »
Having the same issue with the Steelbook from Best Buy. Brand new ASUS BW-16D1HT with the 3.02 firmware. Sent in the dump just now.
1wayjonny
Post by 1wayjonny »
Best buy version - volume key unknown.
Uploaded my files yesterday but still no go.
met_fan
Post by met_fan »
Uploaded my dump file a couple days ago, too. Not working yet.
muggito
Post by muggito »
First time forum poster here, been using MakeMKV for about 8 months now but new to UHD.... the Best Buy version of this disk is working now. We just tried a moment ago. Instead of just creating a dump file, we also got the below messages on MakeMKV. Two questions: Can someone please tell me if the red highlighted part means that the Hashed Keys will automatically download going forward... or do I still need to monitor the Hashed Keys thread and download manually? Also, what does the blue highlighted part mean in regards to downloading the latest SDF... couldn't figure out what that was? I am finding conflicting information in the forums, but then I see that some of those threads are nearly a year old. I want to make sure that the "just keep trying the disc" method is what's recommended after emailing in any dump files. I think the last revision date on the Hashed Keys is early 2018. Thank you in advance. This has been incredible for us with all the help in the forums.
MakeMKV v1.14.3 win(x64-release) started
Saved SD dump file as C:/Users/<omitted>/.MakeMKV/dump_SD_<omitted>.tgz
Downloading latest SDF to C:/Users/<omitted>/.MakeMKV ...
Using LibreDrive mode (v05 id=<omitted>)
Downloading latest HK to C:/Users/<omitted>/.MakeMKV ...
File 00002.mpls was added .... <omitted the rest... but the rest of the titles were added without issue>
LurkerSteve
muggito wrote: Fri Mar 15, 2019 11:12 pm First time forum poster here, been using MakeMKV for about 8 months now but new to UHD.... the Best Buy version of this disk is working now. We just tried a moment ago. Instead of just creating a dump file, we also got the below messages on MakeMKV. Two questions: Can someone please tell me if the red highlighted part means that the Hashed Keys will automatically download going forward... or do I still need to monitor the Hashed Keys thread and download manually? Also, what does the blue highlighted part mean in regards to downloading the latest SDF... couldn't figure out what that was? I am finding conflicting information in the forums, but then I see that some of those threads are nearly a year old. I want to make sure that the "just keep trying the disc" method is what's recommended after emailing in any dump files. I think the last revision date on the Hashed Keys is early 2018. Thank you in advance. This has been incredible for us with all the help in the forums.
Can't comment on HK/SDF but I can say that the developer added support to automatically download keys some time ago so yes, it will download automatically. The default option is to do it. The option is in preferences.
Also, can confirm, able to extract the contents of my disc as well.
apguy
Post by apguy »
My copy is now ripping fine. It does use libredrive mode to rip it
jkeener88
Post by jkeener88 »
I just ripped The Predator 4K UHD fine, no problems.
Then tried this Fantastic beasts Crimes regular Blu-ray and keep getting this, try like 10 times now...
Debug logging enabled, log will be saved as C:\Users\gpadd/MakeMKV_log.txt
Evaluation version, 29 day(s) out of 30 remaining
Using LibreDrive mode (v05 id=E064BA3E3F81)
DEBUG: Code 2399330320 at \#rPZT23K2g>[qvcK:29396299
DEBUG: Code 0 at 3n|Kn0<$@PHq+zen:213133871
Saved AACS dump file as C:\Users\gpadd/.MakeMKV/MKB_v66_Fantastic_Beasts-_The_Crimes_of_Grindelwald_90F6.tgz
DEBUG: Code 0 at jFJ/sedl|n^h9"'$:29396115
DEBUG: Code 0 at jFJ/sedl|n^h9"'$:213134262
ASUS BW-16D1HT 3.01
