Transformers 5 Movie Collection UHD disks won't mount
dmoor1
I've tried to use MakeMKV on several of the disks, but they fail to mount on my LG BE16NU50 with a no "disk inserted" error in MakeMKV. I'm on an iMac Pro 10.14.4 MakeMkv 1.14.3. The error code for Transformers Dark of the Moon is DEBUG: Code 0 at Y0L79-M^~TWfA|&v\B7$yn/z=:121263153. There is no log file.
Re: Transformers 5 Movie Collection UHD disks won't mount
What firmware is on your LG BE16NU50 ? It shows in make mkv post the info or screenshot with sn covered
dmoor1
have any UHD disks worked?
@dmoor1,
Have you enabled downloads in MakeMKV settings? Has the latest hashed keys been downloaded?
dmoor1
Thanks everyone for your help.
Since I never had problems with UHD disks before, I tried a disk which had successfully ripped before and it failed. Looking at the Transformer disk, as careful as I normally am, it looks as if it got some hand lotion on it and that clogged the lens.
So I've ordered a blu-ray lens cleaner from Amazon. If anyone has any specific recommendations about the best way to clean the lens would love to hear them.
