Trying to decrypt 2 blu-ray films and its not saving them
I am trying to decrypt air force one and the rock both blu-ray and both have failed to save, i have attached a log
				setarip_old
Re: Trying to decrypt 2 films and its not saving them
Hi!
What is the nature of the source material?
						AACS directory not present, assuming unencrypted disc
Sorry both blu-ray films
				setarip_old
Re: Trying to decrypt 2 blu-ray films and its not saving the
Sorry, there's no such thing.
Is your source material original, commercial BluRay discs, backup copies of BluRay discs that you made, or files you obtained elsewhere?
If backup copies, what software and procedures did you use to make them?
If original, commercial BluRay discs, what software and procedures did you use to eliminate the AACS directory ?
